VW Polo 6N: Key Programming Guide
chriskross
Post12-04-2010, 6:57    Subject: VW Polo 6N: Key Programming Guide Quote
Hello!
I want to program a new key for my Polo 6N, manufactured in 1998, but I don't have the login code.
Is it possible to read the code via OBD2, or does anyone know of a tool that can do this?
Siemens 6H0 953 257 B TMS 370 MCU.
chris
A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 21:42.
Post12-04-2010, 7:16    Subject: VW Polo 6N: Key Programming Guide Quote
chriskross wrote:
Is it possible to read the code via OBD2...?
No, because the Polo 6N still has the external WFS box. You can't retrieve the login information via OBD for that. Instead, you have to remove and disassemble the box.
The best thing to do is simply take it to a mechanic and have them fix it.
Translated on 30-10-2026, 21:43.
mullemaus
Post12-04-2010, 17:10    Subject: VW Polo 6N: Key Programming Guide Quote
No, because the Polo 6N still has the external WFS module. You can't retrieve the login information via OBD for that. Instead, you have to remove and disassemble the module.
The best thing to do is simply go to the mechanic and have them fix it.
If at least 1 key is still paired and present, then it can be read out without any problems via OBD icon_wink.gif.
Translated on 30-10-2026, 21:44.
Post12-04-2010, 17:27    Subject: VW Polo 6N: Key Programming Guide Quote
mullemaus wrote:
If at least 1 key is still paired and present, then it can be read out without any problems via OBD. icon_wink.gif
Really? That's new to me. Tell me more about it. I was only familiar with the method using a test clip and an EEPROM reader.
Translated on 30-10-2026, 21:45.
mullemaus
Post12-04-2010, 17:31    Subject: VW Polo 6N: Key Programming Guide Quote
Bracket? EEPROM reader? On an MCU? icon_lol.gif I don't think so. icon_wink.gif
It connects easily via OBD using a special tool. Even on a Golf3 icon_wink.gif.
Translated on 30-10-2026, 21:46.
chriskross
Post14-04-2010, 17:49    Subject: VW Polo 6N: Key Programming Guide Quote
It connects easily via OBD using a special tool, even on a Golf3 icon_wink.gif
Hi!
I tried it with the 7.8 special tool, but unfortunately, it didn't work. I received the following response from support:
Immobilizer does not allow reading of memory by not clear reasons. This means
"Cannot read the immobilizer code from this module using the OBDII pin code."
But maybe I did something wrong. Do you have any suggestions?
Device identification: 6H0953257A im*o VWZ3Z0W0163848 V68
Coding: 9600
Supplier number: 00470
A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 21:47.
mullemaus
Post14-04-2010, 23:33    Subject: VW Polo 6N: Key Programming Guide Quote
What were you trying to read? How many pins does the box have? (6...8...10) If possible, please send me a picture of it. Also, if possible, a picture of the circuit board.
Translated on 30-10-2026, 21:48.
chriskross
Post15-04-2010, 9:24    Subject: VW Polo 6N: Key Programming Guide Quote
Hello, the box has 8 pins.
I tried it with the TMS Immo 1 setting, as well as the other HC05 and HC 05-2400 settings.
I can take the photos on the weekend.
best regards, chris
A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 21:49.
mullemaus
Post15-04-2010, 11:04    Subject: VW Polo 6N: Key Programming Guide Quote
Okay, the 8-pole version is an intermediate option. It might not work. The 6-pole versions are the ones mentioned in the program, and the 10-pole version is the one that the TDI-GTI-4-Motion refers to. Only a special programming device will work, or you'll have to tow the car to a VAG dealership and have them program it there icon_wink.gif.
Translated on 30-10-2026, 21:50.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts Pairing key VW Crafter On-Board Diagnostics (OBD)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
No new posts Audi A6 Key Programming: Can it work with A8? On-Board Diagnostics (OBD)
