Passat 3BG: No Access to Control Units
POLO20VTURBO
Post03-05-2010, 17:47    Subject: Passat 3BG: No Access to Control Units Quote
I'm having the following problem:
"I'm unable to perform a diagnostic check because the diagnostic device isn't finding any control units. The error code 1551 indicates something about the K-line, possibly related to the positive power line. I've already measured the cables at the diagnostic connector, both the black and red ones, and both are receiving power when the ignition is on."
Regarding the radio, nothing has changed; it still has the original MFD radio.
What could it be! Does anyone have a clue? I'm at my wit's end.
Okay, one more thing: I already went to a VW dealership, but they couldn't read the data using a Gutmann tester. Then I went to an independent workshop, and they were somehow able to access the data using what I think was a Siemens test device.
Or could it be due to the mass electrodes!
Translated on 03-10-2026, 5:24.
mullemaus
Post04-05-2010, 18:24    Subject: Passat 3BG: No Access to Control Units Quote
Fuse okay? Disconnecting the battery for a short time might also help.
Translated on 03-10-2026, 5:26.
POLO20VTURBO
Post04-05-2010, 19:14    Subject: Passat 3BG: No Access to Control Units Quote
"The fuses are all fine! I'll disconnect the battery again and try again on Thursday. Any further tips would be helpful!"
No new posts Adblue System Malfunction – No Error Code or 28653 / P204F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CAN Bus Access Denied: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts ECU Tuning: No Access to EDC17 MSG On-Board Diagnostics (OBD)
No new posts Crash VAG Com when accessing specific ECUs On-Board Diagnostics (OBD)
No new posts Passat 3B: No Turn Signal When Locking/Unlocking On-Board Diagnostics (OBD)
