b4 tdi steuergerät defekt??? | Posts 16+
Go to page: Previous  1, 2
[email protected]
Post12-07-2009, 16:22    Subject: Quote
I believe the wiring is already in place, but the vehicles haven't been equipped with WFS yet.
Translated on 27-10-2026, 13:07.
Wiesel
Post12-07-2009, 16:29    Subject: Quote
My answer was also meant to be more general and not just related to the older parts icon_wink.gif.
[email protected]
Post12-07-2009, 16:48    Subject: Quote
Okay, I understood it that way too. Thank you.
I was just wondering if anyone has tried it before and can tell me if it works or if I should just avoid it. It's still uncertain when my part will arrive, but I could potentially pick up the 8A0907401A part nearby.
wolfi_b
Post13-07-2009, 13:09    Subject: Quote
Did you check the fuse, though?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 27-10-2026, 13:08.
[email protected]
Post19-07-2009, 14:50    Subject: Quote
Hi everyone, the car is running again. It was the control unit (ECU). I installed a used replacement, and the car started right up.
Wiesel
Post19-07-2009, 19:55    Subject: Quote
I suspect you unfolded the two circuit boards from the old device.
"What often happens with those old devices is that the flat ribbon cable breaks."
(Phthalates gone?).
Translated on 27-10-2026, 13:09.
Mad Dog
Post13-05-2010, 13:50    Subject: Quote
Hello!
hello everyone, another question for you. Has anyone of you perhaps installed a different part before, for example, instead of 8a0907401b, using 8a0907401a?
I'm going to assume that you originally have a part number 8A0907401B.
Can I find out if you installed and got the 8A0907401A working, or if you obtained an 8A0907401B?
Thank you & Best regards.
Christian.
Translated on 27-10-2026, 13:10.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control Unit Failure (VAG): No Power & Clicking Noise On-Board Diagnostics (OBD)
No new posts control unit settings On-Board Diagnostics (OBD)
No new posts 1Z Control Unit: No WFS? On-Board Diagnostics (OBD)
No new posts AAT/AEL Control Unit: Function & Troubleshooting On-Board Diagnostics (OBD)
