Do you need a DZR guide?
Post30-05-2003, 15:41    Subject: Do you need a DZR guide? Quote
Hello.
The DZR (ventilation calculator) seems to cause comprehension problems from time to time, especially for beginners.
What are your thoughts (everyone) on the need for a kind of user manual?
Would that be a good idea, or do you see it as an attack on the level of the website (-> explaining things that each member should be able to understand on their own)? icon_question.gif
Post30-05-2003, 15:52    Subject: Do you need a DZR guide? Quote
Hello Ulf,
I just took another look at the computer. At first glance, I can't find anything that would be unclear. icon_razz.gif
DocSnydor
Post02-06-2003, 10:24    Subject: Do you need a DZR guide? Quote
I haven't really looked into it yet... icon_redface.gif But I would spontaneously wonder where I would get the torque values from... icon_wink.gif
Ernst S.
Post02-06-2003, 12:13    Subject: Do you need a DZR guide? Quote
If your engine has a similar torque curve to the AFN engine, you only need to take the values from the 'Calculated Torque' column. (After you have previously entered the power and torque values at 2000 RPM at the top).
Ernst.
Varianti
Post04-06-2003, 9:21    Subject: Do you need a DZR guide? Quote
At first, I had a problem because I didn't know how to input the measured time. After all, that's the value I'm measuring. It took me a while to figure out that I had to iteratively change the 'Performance' field.
Perhaps it should be added that the 'performance' field should be adjusted until the measured time is achieved.
Alternatively, you can use the Excel function 'Menu: Extras -> Goal Seek'.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts UHV in the Touran - what else is needed? Electrical Systems, Vehicle Electronics, Multimedia
No new posts MFA: What is required for a retrofit? Diesel Engine Technology
No new posts Airbag malfunction, new coil spring needed? Transmission, Chassis, Body & Interior
No new posts 2.0TDI AZV - Is a catalytic converter needed to reduce ex... Diesel Engine Technology
