Update ALH on ASV software?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
TDI-Extrem-Power
Post02-06-2010, 14:27    Subject: Update ALH on ASV software? Quote
I would like to know if, for example, a Bosch service center can update the software from an ALH engine control unit to an ASV one.
I am 100% certain that it is possible to install ALH software, from ALH Automatik, into a Bosch system via a software update.
I have an ALH engine with 0.216 injectors, and I'm hoping that the software update will increase the boost pressure/power.
Perhaps someone here is familiar with this issue:
Since I installed the larger nozzles, the engine sounds different at idle, as if it's running at too low an RPM, but the actual RPM is fine!
"For example, if I'm slowly approaching an intersection and I've depressed the clutch, it sounds like the engine is running on only 3 cylinders. Can anyone explain why this might be happening?"
The injectors were adjusted to 220 bar at the Bosch service center. They are brand new, 100% matching 0.216 injectors, along with brand new Bosch injector holders and needle lift actuators.
When I install the original, older nozzles, everything works normally!
vwSchrauber
Post02-06-2010, 14:58    Subject: Update ALH on ASV software? Quote
Okay, I know this thread is probably going to be locked eventually...
I wanted to ask if, for example, a Bosch service center can update the software from an ALH engine control unit to an ASV one.
No, he wouldn't do that even if he could.
I have an ALH engine with 0.216 injectors, and I hope that the software update will increase the boost pressure/power.
The opposite would be true if you had ASV SW installed. Why that can be inquired via private message, but only for "the chosen ones" icon_exclaim.gif.
If, for example, I'm slowly approaching an intersection and I've depressed the clutch, then it sounds like the engine is running on 3 cylinders. Can someone explain to me why this is happening?
Because the pump voltage is not compatible with the nozzles. Component tolerances take care of the rest.
When I install the old, original nozzles, everything is perfectly normal!
What the above confirms.
My advice: find a skilled tuner who can adjust it for you. Furthermore, you will then need noise and exhaust reports, etc., to obtain the operating permit for the vehicle again, unless you only drive it away from public roads (which I assume you do, because you wouldn't illegally install different nozzles icon_wink.gif icon_lol.gif).
EDIT:
I am 100% certain that you can install ALH software, from ALH Automatik, onto a Bosch system via a software update, of course.
You don't need that, you already have the automatic software installed. She's just not active right now.
Post02-06-2010, 18:38    Subject: Update ALH on ASV software? Quote
My tip: find a skilled tuner who can adjust it for you.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Update software On-Board Diagnostics (OBD)
No new posts Software for BMW? On-Board Diagnostics (OBD)
No new posts AFN/ALH Technology: Software & Systems Diesel Engine Technology
No new posts VAG Diagnostics: vd.exe Software v2.9 Diesel Engine Technology
