eStone-NRW
Joined: 05/30/2010 Posts: 3 Karma: +0 / -0 Location: Dresden
30-05-2010, 17:40 Subject: Passat 3C: Gateway Replacement Guide |
Hi!
Currently, my car, a 3C Variant 2.0 TDI with DSG transmission, manufactured in 2007, has the gateway module 3C0 907 530 C installed.
Due to various upgrades, I would need a newer version.
I've already tried the H and K.
I'm having the same problem with the steering angle sensor on both of them.
I can only make it known using address 04. However, when I activate it there, it unfortunately cannot be found. The scanner says it's not present. This also results in errors in the braking electronics. It doesn't appear to be an error message related to a missing zero position.
The sensor is currently located at the C-gateway with the address 00.
Should I trade in more items to get the newer gateway?
Are there perhaps other versions that might communicate better with my configuration?
Below is an overview of the log.
Greetings.
eStone
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: Error 0010.
42-Volt electric vehicle driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-inch electric auxiliary passenger seat -- Status: OK 0000
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: Error 0010.
5D Control Unit -- Status: OK 0000
62-High voltage circuit breaker, high current -- Status: OK 0000
72-volt electrical, high, right -- Status: OK 0000
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
Translated on 30-08-2026, 18:48.
vagtuning Guest
03-06-2010, 10:42 Subject: Passat 3C: Gateway Replacement Guide |
Indexes E, H, L, and Q should work.
Index K and P are for vehicles equipped with Adaptive Cruise Control (ACC), which you probably don't have installed.
Please note that if you have the PFSE, the software for the telephone keypad needs to be updated.
'It needs to be replaced by a dealer, otherwise you'll experience continuous battery drain.'
The Gateways with a higher index C are only compatible with 5D STG software versions 0019 or higher.
can communicate.
Translated on 30-08-2026, 18:52.
eStone-NRW
03-06-2010, 11:50 Subject: Passat 3C: Gateway Replacement Guide |
I'm going to try again with a new GW (presumably a type of equipment or software) using the index Q.
Regarding the telephone control unit:
Here's my log:
Address 5D: Control Unit
Label file: DRV\3C0-035-151.lbl
Part number SW: 3C0 035 151 C, HW: 3C0 035 151 C.
Component: J738 011 0018
Revision: 00011000
Operating Number: WSC 00000 000 00000
No error codes found.
Do you know if this can be updated? It seems like it would only need to be updated from 0018 to 0019 or higher.
Greetings.
eStone. Passat 3C Variant 2.0 TDI, 140PS PD, DSG, DPF, MJ07 - Comfortline
Translated on 30-08-2026, 18:54.
vagtuning Guest
03-06-2010, 11:58 Subject: Passat 3C: Gateway Replacement Guide |
You'll need to have that updated, and yes, it's possible!
Translated on 30-08-2026, 18:55.
eStone-NRW
09-06-2010, 16:46 Subject: Passat 3C: Gateway Replacement Guide |
I had my first attempt today regarding the software update on the  .
Unfortunately, it didn't find any updated software.
I've just seen in the diagnostic report from the VAS 5051B that they were only looking for updates for address 77, which is the hands-free system.
Just so that I can be sure next time, I'll give them the tip with the address 5D.
The software update should still be found using the "old" C gateway, right? Or do I need to install the new one first?
Greetings.
Translated on 30-08-2026, 18:56.
