Frage zu MWB 11 | Posts 16+
Go to page: Previous  1, 2
Post22-06-2010, 21:25    Subject: Quote
You can see that right at the beginning, after the connection is established. I thought that was mentioned in the instructions!
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Translated on 05-09-2026, 8:00.
ThomasJ
2000 Volkswagen Passat
Post22-06-2010, 21:28    Subject: Quote
Hello.
Yes, I know that, but it only says "EDC" there. But how can I tell if it's an EDC 15 or something else?
Best regards, Tom.
Post22-06-2010, 21:41    Subject: Quote
A part number should follow, for example, mine is 028 906 021 D.
The number depends on the engine and the vehicle.
"vg"
Translated on 05-09-2026, 8:01.
ThomasJ
Post22-06-2010, 21:58    Subject: Quote
Hello.
Yes, I have the same number.
Best regards, Tom.
Post22-06-2010, 22:00    Subject: Quote
Check the letters! (Referring to an AFN - possibly a code or abbreviation)
Translated on 05-09-2026, 8:02.
Post23-06-2010, 6:40    Subject: Quote
You have an MSA15. VCDS displays the VAG part number, software version, and coding information in the control unit information.
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
No new posts Question about the AGR system in the ACV/T4 (Sorry) Diesel Engine Technology
No new posts Oil Question: Get Answers Now! Diesel Engine Technology
No new posts ASR Issue: Audi 8D/B5 Questions On-Board Diagnostics (OBD)
