Login Error: A4 2.0 TDI - Troubleshooting Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
anderl85
Post27-06-2010, 20:36    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
First of all, greetings to everyone.
I'm brand new to this forum, although I've been actively exploring it for several days already.
Recently, I became the proud owner of a "Diagnosetool Profi CAN USB," and of course, I've already used it for all sorts of things (mostly useful ones).
Now I wanted to lower the idle speed in the MSG, as it seems a bit too high. Unfortunately, this apparently only works with a login.
The control unit did not accept the login "12233", which is known to be used in some cases. However, I haven't found any information online or in this forum suggesting that there are other logins for the 4-cylinder diesel engines.
The vehicle should not have any chip tuning or other modifications, as it is a former lease car from Siemens.
Here are some more details:
First registration: 03/2006.
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BLB.lbl
Part number SW: 03G 906 016 JD, HW: 028 101 265 4.
Part number: R4 2.0L EDC G000SG 9905.
Revision: --H02--- Serial Number:
Encoding: 0000072
Operating number: WSC 49930 141 78974
No error codes found.
Readiness: 0 0 0 0 0
It would be great if you could enlighten a newbie...
Here's another piece of information: VCDS version: DRV 908.2.
Translated on 27-07-2026, 18:03.
mullemaus
Post28-06-2010, 0:30    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
This login is also not set up/intended icon_wink.gif. There are some for these engines, but not this one anymore icon_biggrin.gif.
Translated on 27-07-2026, 18:06.
anderl85
Post28-06-2010, 0:44    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Then your answer will lead to two more questions for me.
Does this have anything to do with this specific engine (16V without a DPF)?
Which login is the correct one then?
"About six months ago, I took my car to the mechanic because I thought it was vibrating too much at idle. I had recently switched from a 1.9 TDI, and in direct comparison, it was extremely noticeable."
The friendly technician then installed a software update for me, but I didn't notice any difference compared to before. Is it possible that the workshop couldn't install new software without logging in?
Translated on 27-07-2026, 18:07.
mullemaus
Post28-06-2010, 0:53    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Is it possible that the workshop was also unable to install new software without logging in?
No icon_wink.gif.
Translated on 27-07-2026, 18:08.
anderl85
Post28-06-2010, 0:59    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Hmm,
On the one hand, it's reassuring that I have the latest software version installed, but on the other hand, icon_sad.gif it doesn't help me at all.
How do I obtain that, or the correct login code? And why doesn't anyone else ask for it here?
Translated on 27-07-2026, 18:09.
mullemaus
Post28-06-2010, 1:07    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
And why isn't anyone else asking about it here?
I think it's because nobody has problems with their idle speed icon_lol.gif icon_wink.gif.
How do I obtain the correct login code?
Are the possible login codes not displayed in the mouse cursor within VCDS? Check with support; they may have more information icon_wink.gif.
Translated on 27-07-2026, 18:10.
anderl85
Post28-06-2010, 1:15    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Well, I don't really understand what "activating" and "deactivating" GRA means, because I have no interest in disabling my cruise control.
Why were the login codes changed?
--> Apparently, I'm talking to an insider icon_biggrin.gif.
Translated on 27-07-2026, 18:11.
Post28-06-2010, 8:45    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Translated on 27-07-2026, 18:12.
anderl85
Post28-06-2010, 11:57    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Okay.
Then the next question is:
Wie komme ich ohne Login an besagten Datensatz? VAGDashCAN?
Please tell me there's another way!
Translated on 27-07-2026, 18:13.
Post28-06-2010, 12:25    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Clicking on the file link in VAGCOM would be too easy, wouldn't it?
mullemaus
Post28-06-2010, 22:48    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Ok,
anderl85
No, Rainer means that the 'dataset' refers to the content of the flash memory. icon_wink.gif This can only be read out using hardware/software like Byteshooter.
Translated on 27-07-2026, 18:14.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motorsteuergerät nimmt Login nicht an On-Board Diagnostics (OBD)
No new posts 4-stelliger WFS-Login Code nicht vorhanden, was nun? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Q7 3.0TDI cannot regenerate anymore Diesel Engine Technology
No new posts VW Passat 2.0TDI N75 wird nicht angetaktet Diesel Engine Technology
