1.9 TDI suddenly lost power and has an unstable idle
txtxtx
Post13-07-2010, 12:07    Subject: 1.9 TDI suddenly lost power and has an unstable idle Quote
hello
"Yesterday evening, I finally got the 1Z engine running in my T4. It was running quite well, until now. I was planning to take it for a wheel alignment. I was driving on a detour and accelerated. Then, at around 100 km/h, the power suddenly cut out. I pressed the clutch and let it coast. The idle was rough, and it wouldn't move even a meter."
It also struggles to accelerate properly due to the engine's occasional misfires. Sometimes it runs smoothly, but when you try to accelerate or start moving, it runs unevenly and stalls.
What could be the reason for that?
Best regards, Thomas.
ollli
Post13-07-2010, 14:10    Subject: 1.9 TDI suddenly lost power and has an unstable idle Quote
Hello.
Check the error memory. There might be air in the fuel lines.
Best regards.
Olli.
txtxtx
Post13-07-2010, 17:57    Subject: 1.9 TDI suddenly lost power and has an unstable idle Quote
The error memory will not be read until tomorrow. Unfortunately, I don't have an OBD cable.
"There can't be air in the line. How would it even get there? It was properly bled and running smoothly, as I said..."
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 2,4 & 2,8 l Motoren, unrunder Leerlauf Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts steuergerät defekt (VAG) keine leistung mehr und klackern On-Board Diagnostics (OBD)
No new posts afb 2,5l tdi ab und zu keine leistung Diesel Engine Technology
No new posts 1z no power Upload
No new posts golf 1z keine leistung Diesel Engine Technology
