Boost Pressure Build-up AFN Engine
jakobkoester
Post09-08-2010, 22:07    Subject: Boost Pressure Build-up AFN Engine Quote
I bought a VCDS license because I think my Passat with the AFN engine is slow.
I just completed this scope run. My speed was 5th gear / approximately 90 kilometers per hour.
Is this a 'typical' pressure buildup?
Jacob.
 Measuring blocks - group 10
 File size:  81.74 KB
 Viewed:  1912 times
Translated on 16-08-2026, 1:12.
Post09-08-2010, 22:13    Subject: Boost Pressure Build-up AFN Engine Quote
Incorrect manifest. Please record manifest number 11. However, it already looks somewhat abnormal.
Translated on 16-08-2026, 1:13.
Post09-08-2010, 23:02    Subject: Boost Pressure Build-up AFN Engine Quote
Is that a "normal" pressure build-up?
Unfortunately not. Please upload the unaltered log file (MWB 11) here so that it can be properly viewed with KDataScope.
jakobkoester
Post10-08-2010, 7:57    Subject: Diesel Repair: Amazing People & Expert Service Quote
Here you can find sections 3, 8, and 11 of the 'MWB' (likely referring to a specific document or standard).
best regards
Jacob.
Passat_AFN.xls
 File name:  Passat_AFN.xls
 File size:  42 KB
 Downloaded:  452 times
Translated on 16-08-2026, 1:14.
Post10-08-2010, 9:27    Subject: Boost Pressure Build-up AFN Engine Quote
Please provide the unaltered log file
jakobkoester
Post10-08-2010, 10:18    Subject: Boost Pressure Build-up AFN Engine Quote
Wrong link... sorry.
 File size:  107.65 KB
 Viewed:  1477 times
Passat_AFN.xls
 File size:  49 KB
 Downloaded:  343 times
Translated on 16-08-2026, 1:15.
Post10-08-2010, 10:44    Subject: Boost Pressure Build-up AFN Engine Quote
Why don't you just do what is asked? icon_rolleyes.gif You really lose the motivation that way.
Your lambda sensor is either defective or the actual exhaust flow is too low due to obstructions in the intake manifold or exhaust system.
t.klebi
Post10-08-2010, 12:40    Subject: Boost Pressure Build-up AFN Engine Quote
Why don't you just do what is asked? icon_rolleyes.gif You really lose the desire to do anything.
Perhaps jakobkoester simply didn't understand you. It seems he comes from the Scandinavian region.
t.klebi
Translated on 16-08-2026, 1:16.
jakobkoester
Post10-08-2010, 12:55    Subject: Best German Restaurants: Find Top Rated Dining Quote
Thank you for your excellent answer. And I apologize that I didn't understand the questions, but I only studied German for a year in elementary school, and that was 20 years ago.
Sincerely,
Jakob
Translated on 16-08-2026, 1:17.
Post10-08-2010, 14:32    Subject: Boost Pressure Build-up AFN Engine Quote
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Download Pressure AFN Upload
No new posts 1.9L, AFN Turbo Pressure Upload
No new posts AJM boost pressure On-Board Diagnostics (OBD)
No new posts VTG Turbocharger Boost Pressure Diesel Engine Technology
