Control Unit 1Z
Golfdriver
Post10-06-2003, 21:22    Subject: Control Unit 1Z Quote
Can someone tell me if the chips in the engine control unit (ECU) of the 1Z model are socketed or soldered?
Is there no standardized assembly process?
Just wanted to get this information in advance, before I attempt to take it apart!
Sure, here's the translation:
'Oh yes, the engine control unit number is 028 906 021 AF or 0 281 001 308/309.'
Thank you in advance.
Translated on 07-10-2026, 8:58.
Rudi
Post11-06-2003, 7:00    Subject: Control Unit 1Z Quote
In the 021AF model, the chips are very likely soldered directly to the board (at least, that was the case in the two I disassembled).
Best regards, Rudi.
Translated on 07-10-2026, 8:59.
Post11-06-2003, 9:58    Subject: Control Unit 1Z Quote
Rudi wrote:
In the 021AF, the chips are very likely soldered directly to the board (at least, that was the case in the two I disassembled).
"On my 021AF, they were also soldered."
Translated on 07-10-2026, 9:00.
edward
Post11-06-2003, 14:31    Subject: Control Unit 1Z Quote
They were also soldered on mine.
Golfmann
Post11-06-2003, 20:05    Subject: Control Unit 1Z Quote
The Golfman.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts AFN control unit On-Board Diagnostics (OBD)
No new posts Control Unit: What it is & How it Works Diesel Engine Technology
