Brösel Guest
11-06-2003, 11:23 Subject: Outdoor Temperature Display Malfunction! |
Is my outdoor temperature display inaccurate?
Translated on 14-08-2026, 2:41.
vikinger Guest
11-06-2003, 12:31 Subject: Outdoor Temperature Display Malfunction! |
I'm experiencing similar issues. The display initially shows incorrect information, but after a few minutes of driving, it eventually displays the correct value. However, I haven't really thought about what might be causing this yet.
Translated on 14-08-2026, 2:42.
PrivatBereich Guest
11-06-2003, 14:59 Subject: Outdoor Temperature Display Malfunction! |
IMHO, it could also be due to water or moisture on the sensor. In that case, a slight evaporative cooling effect would occur initially, and the temperature of the water droplet would be displayed. Once the moisture evaporates, the sensor temperature would rise to match the outside air temperature.
Just a thought...
Julian Guest
11-06-2003, 15:30 Subject: Outdoor Temperature Display Malfunction! |
HI!
It happened to my Golf 4 too. If the sensor (located in the black grid below the driver's headlight in the bumper) is definitely dry and clean, then try removing the sensor and cleaning its contacts.
If that doesn't help, the only solution is to replace the sensor, which isn't very expensive. It's not a problem with the instrument cluster!
Translated on 14-08-2026, 2:43.
Julian Guest
12-06-2003, 7:21 Subject: Outdoor Temperature Display Malfunction! |
Well, mine was also a bit slow to respond. I parked it in the shade, and it only showed 15°C (59°F), even though it was already 30°C (86°F) outside. The climate control system then operated at a reduced level.
After some time, the temperature suddenly increased dramatically. I would replace it!
Translated on 14-08-2026, 2:44.
Uwe Profi-Schrauber
Joined: 04/15/2002 Posts: 1004 Karma: +5 / -0 Location: Westerwald
12-06-2003, 10:08 Subject: Outdoor Temperature Display Malfunction! |
Hi!
There are two temperature sensors: one in the bumper and another in the air box, within the airflow of the interior ventilation system. It is likely that ONE of these sensors is providing an implausible reading.
You can query the values using the Climacodes. For Audi, it's channels 58 and 59, while for VW, I believe it's different channels. This allows you to check the sensors with minimal effort.
Uwe Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 14-08-2026, 2:45.
Julian Guest
12-06-2003, 11:01 Subject: Outdoor Temperature Display Malfunction! |
Okay, but the module located in the dashboard isn't responsible for the display of tire pressure information on the instrument cluster or multifunction display; that's solely the responsibility of the module located in the bumper!
Translated on 14-08-2026, 2:46.
