Bleed brakes with ABS, Bosch version 5.3
voss
Post13-06-2003, 18:28    Subject: Bleed brakes with ABS, Bosch version 5.3 Quote
Hello.
How can the ABS braking system be bled using diagnostic software VCDS (VAG-COM) and BOSCH ABS Ver. 5.3 control unit?
In the error database, I only have information for Teves. Can I also use that information for Bosch STG?
Sonst muss ich meine Bremse, nach Bremsschlauch wechseln, normal durch pumpen entlüften. icon_sad.gif
Thank you.
Voss.
Translated on 09-07-2026, 12:23.
No new posts TDI Fuel Pump Priming: How to Bleed It Troubleshooting & Guides
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Bosch ABS/ESP 5.3: Basic Settings & Configuration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Stuck After Bleeding? 3BG PD TDI Transmission, Chassis, Body & Interior
No new posts VP44 Bleeding: How to Bleed Your Injection Pump Diesel Engine Technology
No new posts Coolant pump / Filling and bleeding Diesel Engine Technology
No new posts Bleed Brake Mk 20i Transmission, Chassis, Body & Interior
