Control unit without WFS?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Peter vdl
Post31-08-2010, 21:18    Subject: Control unit without WFS? Quote
Hi everyone,
I'm currently in the process of extracting a 1Z engine from a donor 1994 Passat and I'm not finding any signs of a WFS (immobilizer system). Initially, I thought the DWA (alarm system) module (1H0 953 233 B) might be the WFS, but information about it ranges from "has integrated WFS" to "doesn't exist." So, I'm looking for another way. I haven't found any clues around the ignition switch regarding a reading coil, and now the entire dashboard is removed, with almost all the wiring disconnected, and still no sign of a reading coil or any extra WFS components. Therefore:
Does anyone know for sure whether the MSG 028 906 021 B requires a WFS (Wiring Fault Simulation) and, if so, where it might be located?
The car is quite muddy on the front left side, and there might be something hidden there. I also wouldn't rule out the possibility of pests, as the car has been in a dilapidated condition for a while.
Smoky greetings.
Peter.
fantomas
Karma: +5 / -1   Thank you, like it!
Post31-08-2010, 22:32    Subject: Control unit without WFS? Quote
The engine control units with the designation 021B in the Passat and 021C in the Golf do not have WFS (Waste Heat System), which was only introduced starting with the 1995 model year.
Peter vdl
Post01-09-2010, 6:44    Subject: Control unit without WFS? Quote
Great, thanks!
Then I can search for a long time...
Smoky greetings.
Peter.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steuergerät von TDI umprogrammieren ohne Hardwareveränder Diesel Engine Technology
No new posts Diagnosis of control unit without a vehicle On-Board Diagnostics (OBD)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts 2x2 diagnostic adapter without +12V On-Board Diagnostics (OBD)
