Gas lamp near? Find gas lamps nearby!
Post26-08-2010, 8:12    Subject: Gas lamp near? Find gas lamps nearby! Quote
Hi.
Sure, here's the translation:
"this"
Code:
                 Adresse 01: Motor  (03G 906 018 EM)
07:57:01 Block 068: Partikelfilter (Abgaswerte II)
  39.1 %  Beladungs- koeffizient
  19.51  Aschemasse
  -6.5 %  Aschelernwert
07:57:01 Block 069: Partikelfilter (Regenerationsstatus I)
  00000000  Status 1 Regeneration
  00000000  Status 4 Regeneration
07:57:01 Block 070: Partikelfilter (Regenerationsstatus II)
  746.5 s  Regenerations- zeit
  1.0  Erfolglose Regenerationen
  0.0  Erfolreiche Regenerationen
07:57:27 Block 073: Partikelfilter (Fahrzeugdaten)
  0.0 l  Verbrauch seit Regeneration
  0 km  Strecke seit Regeneration
  0 h  Zeit seit Regeneration
Shouldn't you be presenting me with the yellow gas lamp soon?
Translated on 08-10-2026, 1:58.
Post26-08-2010, 8:30    Subject: Gas lamp near? Find gas lamps nearby! Quote
Should
be presenting me with the yellow gas lamp in the near future, or not? }
Well, if the dataset is designed cleverly, it will first try without using the light, and only if that doesn't work, it will use it.
Post26-08-2010, 9:04    Subject: Gas lamp near? Find gas lamps nearby! Quote
I wanted to remove the failed catalytic converter and the very full DPF.
I don't remember ever seeing it this full before.
I think I'm going to head straight to the sauna after work to relax and sweat it out.
Translated on 08-10-2026, 1:59.
Octavia_4x4
Post03-09-2010, 20:03    Subject: Gas lamp near? Find gas lamps nearby! Quote
icon_lol.gif And precisely this problem leads me to believe that the particulate filter is absurd... it's supposed to protect the environment, but we have to drive around for it to burn off... it constantly frustrates me and makes me angry about our cars.
To clean up the "green conscience" part again, which has caused additional CO2 emissions... icon_lol.gif icon_lol.gif
Translated on 08-10-2026, 2:00.
Post04-09-2010, 8:14    Subject: Gas lamp near? Find gas lamps nearby! Quote
The same applies to other areas (in the automotive industry).
First, the cars are made with a flat front to allow them to cut through the wind with minimal resistance.
Now they're becoming more aggressive again, because someone realized that the pigeons are breaking the bones of poor pedestrians' feet.
Everything has two sides. But the "experts" in the legislature always focus on just one aspect, like a cow being lured into a slaughterhouse. And then their successors (well, there aren't any successors for the cow) rush out, screaming, and throw themselves onto the other side.
First, "we need to drastically reduce fuel consumption." Now, they're using diesel fuel in a way that creates such fine particulate matter that you can't even see it.
And then, a little bit of image-based propaganda for those who don't use regenerative braking on ultra-short distances...
Translated on 08-10-2026, 2:01.
No new posts DPF & Environmental Zones: Quick FAQ Technical Articles
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
No new posts TDI 110/115 PS: Specs & Performance Diesel Engine Technology
No new posts Oil VW 505.01 or 507.00 Upload
