Cold Start Issues: 13°C & Misfires
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
DieselBär30x
Avatar-DieselBär30x
Post13-09-2010, 15:26    Subject: Cold Start Issues: 13°C & Misfires Quote
"EDIT2: Added two cold start logs taken at -4°C and -6°C, showing similar anomalies on cylinder 1."
This time, the idle speed control system is driving the positive deviation (PDE) of cylinder 1 to the regulation limit of +2.99 between 14 and 17 seconds after starting.
This time, the PDE states went from "128" (presumably for engine OFF - logo?) to "16" and then to "0". The "32," which was present in the previous log, is missing this time.
Instead of displaying "128", Steffen's device is showing the value "2". And during the startup process, instead of displaying "16", it's showing the value "6"?
Marker 1 was set approximately 1-2 seconds later than when the engine appeared to be running smoothly.
EDIT:
Added at operating temperature under the same measurement conditions.
Hier LLRR absolut o. B. und weit vom Regelanschlag entfernt, PDE-Stati binnen 1 sec. im Regelbereich (128->16->0.0), BIP wie gehabt (jedoch nicht mehr gar so im neg. Area).
Between marker 1 and marker 2, all electrical consumers were connected to the load (generator load was 99.6% here) -> no noticeable change in the log values.
LOG-01-013-018-023.csv
 Kaltstart-Log bei -6°C
 File name:  LOG-01-013-018-023.csv
 File size:  22.43 KB
 Downloaded:  828 times
 Kaltstart bei -4°C
Kaltstart bei -4°C
 File size:  40.31 KB
 Downloaded:  638 times
LOG-AXC-170910-1-75Grad-01-013-018-023.CSV
 File name:  LOG-AXC-170910-1-75Grad-01-013-018-023.CSV
 File size:  26.04 KB
 Downloaded:  717 times
LOG-AXC-130910-1-13Grad-01-013-018-023.CSV
 File name:  LOG-AXC-130910-1-13Grad-01-013-018-023.CSV
 File size:  6.42 KB
 Downloaded:  746 times
Translated on 27-07-2026, 15:54.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TDI Cold Start: Troubleshooting & Tips Diesel Engine Technology
No new posts ARL Improves Cold Start Performance On-Board Diagnostics (OBD)
No new posts Cold Start Diesel Engine: 101 PS Below 0°C Diesel Engine Technology
No new posts Cold Start: How to Safely Merge onto Highway Diesel Engine Technology
