Injector Code Input (Common Rail)
Frettloeh
Post19-09-2010, 18:30    Subject: Injector Code Input (Common Rail) Quote
After replacing an injector (Audi Q7, 3.0L V6, MKB BUG), a code must be entered for quantity adjustment. How is this done with VCDS?
Thank you.
Bernhard.
Translated on 10-10-2026, 20:11.
Tobi12345
Post20-09-2010, 13:33    Subject: Injector Code Input (Common Rail) Quote
Take a look inside; everything is explained there!
http://wiki.ross-tech.com/wiki/index.php/3.0l_V6_TDI_%28BKS/BMK/BUN%29
edit mod: The URL has been adjusted so that it can be clicked.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 10-10-2026, 20:12.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injector calibration with VCDS Troubleshooting & Guides
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
