Is the BMK engine (3.0 TDI VAG) prone to engine failure?
Frank F.
Post11-10-2010, 14:20    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
Hello everyone!
I have an A6 sitting around with the BMK engine (224 hp / 165 kW) that's gone bad – it has no compression in two cylinders. This morning, a colleague came by who has exactly the same old engine in his A6, and it's also broken down now. His lasted about 20,000 km less, so 150,000 km total. In mine, four fuel injectors were defective; with low pressure (250 bar on the test bench), the injection volume was too high, almost double what it should be.
Is this effect comparable to that of dripping, conventional diesel injectors?
'Are there any forum users who have observed an increase in engine failures with these engines?'
'What are the known issues with piezoelectric injectors? Mine have the Bosch part number 445 150 037. Is there a newer type available for them?'
Questions upon questions...
Best regards!
Frank.
Translated on 21-07-2026, 18:31.
mullemaus
Post11-10-2010, 15:36    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
The injectors of the first generation were prone to failure and, as far as I know, were replaced. I am not aware of any general problems. On the contrary, the 2.7 and 3.0 engines are considered extremely reliable. icon_wink.gif
Translated on 21-07-2026, 18:33.
christians
Post14-10-2010, 13:23    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
Yes, there are occasional instances of total failures with this engine.
Gruß Christian
Frank F.
Post14-10-2010, 15:49    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
Hello everyone!
Here in our fleet, the third A6 is currently showing the same symptoms; it's starting to produce white smoke. All of these are BMK engines. The last one literally exploded, leaving a large oil spill underneath. Since I don't entirely trust our Audi partner, what is the current part number? I have some in a 'new' used engine here, and their part numbers end with the index AA.
Where online can I find a resource that describes what happens to injectors or nozzles when too much fuel is injected or the part drips?
I don't want to waste time and money having to replace the engine again in a few months, just because the same problem occurs as with the faulty one.
Best regards!
Frank.
Translated on 21-07-2026, 18:34.
Arne
Post15-10-2010, 9:58    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
Last week at the Volkswagen dealership in Münster: 6 cars with engine failures, all 3.0 TDI models.
From Phaeton to Touareg to A6 - we have it all.
Don't ask me about license plate numbers or anything like that. My colleague is the head of the receiving department there, and he just mentioned it in passing. I always thought the 3.0 TDI engines were great too.
Greetings.
Translated on 21-07-2026, 18:36.
christians
Post15-10-2010, 12:59    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
As far as I know, this only affects the 3.0 TDI engines. In the case of my former colleague, the cause was not determined because the defective engine block was sent directly to Audi for inspection.
According to his statements, the engine failed catastrophically while driving on the highway, accompanied by a large cloud of smoke.
If the problem is with the injectors, then the 3.0 TDI engines, which were introduced before the 2.7 models, would have experienced the first series of the multiple-improved nozzles.
Gruß Christian
Translated on 21-07-2026, 18:37.
vwSchrauber
Post15-10-2010, 14:13    Subject: Is the BMK engine (3.0 TDI VAG) prone to engine failure? Quote
Step changes in the block or ZK should not be present, as the 2.7 models only differ mechanically from the 3.0 models in terms of stroke icon_confused.gif.
Translated on 21-07-2026, 18:38.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 BiTDI Engine Problems & Repairs Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
