ASV Error Codes: Troubleshooting & Solutions
stefan-der-erste
Post19-06-2003, 13:36    Subject: ASV Error Codes: Troubleshooting & Solutions Quote
I drive a Skoda Octavia TDI with 110 horsepower, engine code: ASV, manufactured in August 2000.
and I read the error memory using VAG-COM.
The engine had the following error codes: 17664 - Temperature Sensor (G62), 19561 - Intake Manifold Flap.
and for the VAT ID: 01367, 01366.
Unfortunately, I only have an English version of the program. Could someone please...?
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Thank you very much.
Stefan.
Translated on 25-07-2026, 17:36.
Post19-06-2003, 13:46    Subject: ASV Error Codes: Troubleshooting & Solutions Quote
Hello Stefan,
Just enter the error codes into the search function, and you'll find things like this:
Error code: 19561.
Solenoid valve for throttle control flap N239 - Short circuit to ground / Open circuit
It sounds like some of your cables might have been chewed on.
Translated on 25-07-2026, 17:37.
stefan-der-erste
Post19-06-2003, 14:39    Subject: ASV Error Codes: Troubleshooting & Solutions Quote
Hello Rainer,
'Thank you, I found it.'
I would also be interested in knowing the location of the temperature sensor G62.
Is that the one located on the transmission side, at the rear of the cylinder head?
Stefan
Translated on 25-07-2026, 17:38.
Post19-06-2003, 17:27    Subject: ASV Error Codes: Troubleshooting & Solutions Quote
I would also be interested in knowing where the temperature sensor G62 is located.
Is that the one on the transmission side, at the rear of the cylinder head?
I don't know icon_redface.gif.
If the error is intermittent, you should be able to identify the sensor using your diagnostic system and by systematically disconnecting the connectors at each temperature sensor.
Translated on 25-07-2026, 17:39.
No new posts Fehlercodes Ursachen und Auswirkungen für MKB AMF, ANY Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercodes VW T4 On-Board Diagnostics (OBD)
No new posts VAG-COM error codes On-Board Diagnostics (OBD)
No new posts Fehlercodes On-Board Diagnostics (OBD)
No new posts Fehlercodes ? On-Board Diagnostics (OBD)
