A6 C5 2.5 V6 TDI: No Power Above 3000 RPM
burli81
Post16-10-2010, 23:33    Subject: A6 C5 2.5 V6 TDI: No Power Above 3000 RPM Quote
Hello!
I've been trying the search function for a while now, and I've found some threads, but none of them have really helped me yet...
Yesterday, I looked at a used Audi A6 2.5 TDI quattro with Tiptronic transmission, manufactured in 1999, with 240,000 kilometers on the odometer. The car has a complete service history and appears to be well-maintained overall.
The problem: The engine runs somewhat normally at low speeds, but above 3000 RPM, it struggles significantly and has very little power.
When I rev it up in neutral, it initially revs well, but something still isn't right. It seems like it hesitates somewhere between 3500 and 4000 RPM, then it revs up to the limiter. When it exceeds this "threshold" in neutral, you can hear a "PFFFT" sound from the front, as if the VTG adjustment system has done something.
The error code stored was: "Intake manifold pressure exceeds regulation limit." After clearing the error, there was no improvement, but it did not reappear after a 2km test drive.
I also performed the actuator diagnosis, and in my opinion, the VTG (Variable Turbine Geometry) adjustment seems to be working quite well.
Furthermore, a friend of mine performed a VAG-COM log and recorded channels 10 and 11. I can gladly post the log tomorrow. From what I could see, the boost pressure was mostly quite consistent, and the maximum boost pressure was around 2.1 bar, if I remember correctly.
Maybe someone here has an idea; I have to decide on Monday whether or not to buy the Audi.
Best regards and thank you from Vienna.
ingo
Translated on 26-09-2026, 20:17.
kuestenkuddel
Post17-10-2010, 22:33    Subject: A6 C5 2.5 TDI: No Power Above 3000 RPM Quote
I have been trying the search function for quite some time now, and I have also found some threads, but it hasn't really helped me yet...}
Hi.
Please try the search function again, and include the following ICD codes: AFB and AKN.
Best regards from Hamburg, Kurt.
Translated on 26-09-2026, 20:20.
vwSchrauber
Post19-10-2010, 14:45    Subject: A6 C5 2.5 V6 TDI: No Power Above 3000 RPM Quote
Keyword for search: camshafts icon_wink.gif
mserge
Post25-10-2010, 17:19    Subject: A6 C5 2.5 V6 TDI: No Power Above 3000 RPM Quote
I highly doubt that. It's more likely to be the turbocharger, or a clogged exhaust system, or something like that. Even with 4 broken camshafts, these engines still run pretty well.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 26-09-2026, 20:21.
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AJT: No Power? Troubleshooting Guide Diesel Engine Technology
No new posts No T4 Acv performance Upload
No new posts No More Performance: What to Do? Diesel Engine Technology
No new posts No power with the TDI! LMM=OK! Diesel Engine Technology
