Auxiliary Heater Installation: Octavia 1U5 1.9 TDI
Octavia_4x4
Post17-11-2010, 10:41    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
While there's already a thread about the Polo's pre-heating system, the Octavia's Climatronic system is different...
Now my question is, is it possible to install a parking heater in an Octavia with a reasonable amount of effort?
I purchased a used device from a recycling center, preferably from a Passat 3BG or Golf IV, as they have the same Climatronic unit.
How difficult is the installation process, and what should I be aware of?
It appears that in the compact class, Eberspächer is focusing on a pure water heater system (DxW, where D = Diesel, x = heating power in kW, and W = water heater). Air heaters, like the one in our T4 that directly heats the interior, seem to be unavailable, and furthermore, there would likely be problems with the piping into the interior.
And generally speaking, it's more sensible to warm up the engine first and avoid starting it when it's cold.
"Does anyone have experience with installation work? I've been putting this project off for two years because I lack the necessary knowledge."
Translated on 16-10-2026, 5:14.
haithamina
Post17-11-2010, 11:52    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
Hello 4x4,
Since you're mentioning the Climatronic system in the 3BG model:
/viewtopic.php?t=20126&highlight=standheizung+3bg
Familiar?
haithamina
Translated on 16-10-2026, 5:16.
wolfi_b
Post17-11-2010, 13:12    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
General installation instructions can be found, for example, here.
You can find more interesting information here: http://www.danhag.de/
When it comes to diesel-powered standing heaters, it's important to note that many are controlled via the CAN bus, which makes them less suitable for retrofitting.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Octavia_4x4
Post17-11-2010, 15:09    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
That's great, I already have so much information now - thank you to everyone involved!
"Of course, I will make sure to get a standard model without CAN functionality to avoid the problems mentioned above!"
Greetings.
Translated on 16-10-2026, 5:17.
Deus Violentia
Post17-11-2010, 17:00    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
Regarding the CAN-Bus issue, this can be resolved as Wolfi mentioned:
http://www.danhag.de/anleitung/w-bus-konverter-v2x.pdf
You'll also find a *lot* of reading material here:
http://www.sgaf.de/forum/sga-iii-sharan-galaxy-alhambra-i-ii/technik/workshop-zuheizerumbau-standheizung-11
http://www.johanneshuebner.com/ge/sharan/sharan-sh.shtml
You also have a private message!
BKD GRF
AHF EBF
Translated on 16-10-2026, 5:18.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post21-11-2010, 21:07    Subject: Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Quote
If it turns out to be an Eberspächer and not a Webasto, I'll have the answers to your questions about the auxiliary heater.
Here's some information about the Climatronic versions of the 3B(G) and the HE mode: /viewtopic.php?t=24039
I recently upgraded the Passat, and I'm still working on the documentation.
Passat Variant BGW 2005
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Octavia 5E: Unlock Parking Heater Function On-Board Diagnostics (OBD)
No new posts Retrofitting a auxiliary heater to a B7 1.6 TDI CAYC Electrical Systems, Vehicle Electronics, Multimedia
No new posts Webasto Heater Remote Control: Retrofit Guide Transmission, Chassis, Body & Interior
No new posts Log BKD Octavia 2.0 TDI Upload
