Towing Hitch Unlock: VW Golf 5 and Newer Models (Solution)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
HightowerJM
Post29-11-2010, 17:50    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
Hi.
I haven't had the VCDS for very long, and I now want to activate the trailer hitch function.
There is a manual available for the Bosal trailer hitch.
It is described on page 22. However, I'm not entirely sure yet how to implement it.
The vehicle was manufactured in 2007 and has parking sensors (PDC), but not a parking assist system.
I would also like to enable the trailer stabilization feature.
Can someone help me with this, or do I need to retrieve something from the car first?
Jens
Translated on 12-08-2026, 11:45.
DieselBär30x
Avatar-DieselBär30x
Post29-11-2010, 18:01    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
Hello Hightower!
First of all, welcome to the club icon_wink.gif.
Please run a complete (error) scan of all STG systems and post the results here.
Depending on the installed equipment (e.g., parking distance control), several software modules may need to be reconfigured.
It may even be necessary to perform a software update on one or more of the storage devices.
All of that would tell us what a complete scan reveals icon_wink.gif.
Best regards from Munich!
Translated on 12-08-2026, 11:47.
Ross-Tech-Support
Post29-11-2010, 18:09    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
The general procedure is described in our wiki...
Retrofitting a Trailer Hitch (AHK Installation)
"...however, as previously mentioned, a diagnostic protocol (auto-scan) is necessary for more specific information."
"The installation instructions from the auction are quite wrong, if you ask me. Not all of the points on page 22 regarding the coding are necessary, let alone actually useful. It seems like someone copied information from Westfalia or a similar source without really understanding what they were doing."
What brand is the electric kit from? This information isn't available either in the auction listing or in the instructions...
Translated on 12-08-2026, 11:48.
HightowerJM
Post29-11-2010, 18:23    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
Thank you very much.
I've already experimented with it a bit. For example, I managed to activate the rear windshield wiper on my Octavia 2, but I couldn't find the setting for the front wipers.
I will only be able to read the car's diagnostic data on Saturday.
If I remember correctly, after the error scan, there's a file that can be saved in the upper left corner, which is probably what you're referring to.
I can't tell you which manufacturer it is yet, as I haven't seen the tow hitch.
Jens
Translated on 12-08-2026, 11:51.
r.bierstedt likes this.
Post29-11-2010, 19:32    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
The Golf 5 / Golf 6 platform (diagnosis, for example, with the MicroCAN) includes the following models:
1K chassis for VW Golf 5 and newer Jetta.
5K chassis for a VW Golf 6.
13-inch chassis for a VW Scirocco.
3C-Chassis (B6) Volkswagen Passat.
VW Passat CC, chassis number 35.
1T Chassis for VW Touran Minivan.
1F-Chassis VW Eos
2K Chassis for VW Caddy.
5M chassis for a Volkswagen Golf Plus.
5N Chassis VW Tiguan.
1F-Chassis VW Eos
8P Chassis for Audi A3 / A3 Convertible.
8J chassis Audi TT.
5P Chassis for Seat Altea and Toledo.
1P-Chassis Seat Leon.
Skoda Octavia, chassis code 1Z.
3T Chassis for Skoda Superb.
5L Chassis Skoda Yeti
Steps for retrofitting a trailer hitch:
- In the CAN gateway, using address 19, encode the "trailer control unit." The VCDS coding assistant (tooltip or LCode) will tell you how.
- If a PDC (Parking Distance Control) is installed (address 76), enter the extension of the rear parking sensor in channel 2 by making an adjustment.
- If the parking assist system is installed (address 10), adjust the coding. The VCDS coding assistant (tooltip or LCode) will tell you how.
- ABS/ESP control unit (address 03), enable trailer stabilization if supported.
- Body control module (address 09), activate the function to disable the rear fog light when towing a trailer. The coding assistant (tooltip or LCode) in VCDS will tell you how.
- Engine control unit (address 01), reprogram to enable trailer hitch (standard or extended programming, depending on the control unit). Ignition must be ON, engine OFF. Unlike previous control units, no login code is required; instead, it is directly programmed.
- If a reversing camera (address 6C) is installed, check and adjust its settings as well through the coding process.
Translated on 12-08-2026, 11:56.
HightowerJM
Post29-11-2010, 19:58    Subject: Towing Hitch Unlock: VW Golf 5 and Newer Models Quote
Thank you very much, Rainer.
I can work with that. (Hopefully.) Otherwise, I'll get back to you.
Translated on 12-08-2026, 11:59.
Ratings - Towing Hitch Unlock: VW Golf 5 and Newer Models
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku alle VAG Fahrzeuge MJ 2002, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Newer ESP generation console, but from the old block Diesel Engine Technology
No new posts Golf 5 TDI WITHOUT electronic components. Zuheizer ??? Transmission, Chassis, Body & Interior
No new posts Funkfernbedienung vom Golf5 auf Golf4 programmieren On-Board Diagnostics (OBD)
No new posts Vehicles with engine 1Z? Diesel Engine Technology
