As you can see in the pictures, cylinder heads from 16V TDI engines can also crack in a way that causes the exhaust side to become completely flooded with water.
That's why the diagnosis with a removed intake manifold is not always correct. I hope this helps other mechanics with troubleshooting and that this potential issue is also taken into consideration.
| Description: |
| Aufbau zum Abdrücken des Zylinderkopf (BKD, 16V TDI) |
 Download |
| File name: |
P1000633.JPG |
| File size: |
5.65 MB |
| Downloaded: |
5100 times |
| Description: |
| 2.Zylinder auslaßseitig undicht, Kühlmittelverlust im Zylinderkopf (BKD, 16V TDI) |
 Download |
| File name: |
P1000631.JPG |
| File size: |
5.54 MB |
| Downloaded: |
4264 times |
