Webasto Heater Diagnostics: Online Software Found
nibi123
Post22-10-2004, 18:51    Subject: Webasto Heater Diagnostics: Online Software Found Quote
I found something interesting for all Webasto owners:
http://bus.webasto.de/support/de/support_applications.html
Unfortunately, I have an Eberspächer heater and I'm looking for the same part for my needs. Does anyone know a link where I can find it?
Translated on 26-09-2026, 18:36.
nibi123
Post22-10-2004, 20:10    Subject: Webasto Heater Diagnostics: Online Software Found Quote
I've found something else, but it's only known by its name: EDiTH (Eberspächer Diagnostic System for Thermo Heating Devices).
But where can you get it?
Translated on 26-09-2026, 18:37.
brezelmann01
Post23-10-2004, 20:00    Subject: Webasto Heater Diagnostics: Online Software Found Quote
Hi!
I've been playing around with the Webasto software today. Unfortunately, I can't connect to my heating system with this version, but I could with the older version. Has anyone else had a similar experience, or can anyone offer a tip on how to fix the problem?
It is a ThermoTop E retrofit system.
Dirk.
[VERKAUFT] Polo 6NF 1.4TDI (AMF) mit nachgerĂźstetem DPF, STH+FFB, Bj. 2000, 222tkm
Thomas Falke
Post25-10-2004, 23:50    Subject: Webasto Heater Diagnostics: Online Software Found Quote
Hello, what you have there is not intended for use with standard interfaces. Eberspächer and Webasto offer their own interfaces for this purpose, as the communication protocol of those devices is different.
Thomas Falke.
Translated on 26-09-2026, 18:38.
brezelmann01
Post26-10-2004, 13:08    Subject: Webasto Heater Diagnostics: Online Software Found Quote
@thomas falke:
Why does it work with the old DOS version then? Actually, it shouldn't work with that either, or am I mistaken?
Translated on 26-09-2026, 18:39.
Thomas Falke
Post26-10-2004, 19:52    Subject: Webasto Heater Diagnostics: Online Software Found Quote
If the auxiliary heating control unit communicates with your PC/laptop, do you receive data?
The program can run, but it won't work with your interface because yours uses a different protocol.
Thomas Falke.
brezelmann01
Post27-10-2004, 10:08    Subject: Webasto Heater Diagnostics: Online Software Found Quote
I already wrote everything!
I've been playing around with the Webasto software a little bit today. Unfortunately, I can't access my heating system with this version, but I could with the older version. Has anyone else had similar experiences, or can anyone give me a tip on how to fix the problem?!
It is a ThermoTop E, installed later.
With the older version, ALL of the program's functions are available in combination with the heating system. Therefore, communication works perfectly!
Translated on 26-09-2026, 18:40.
Max
Post20-06-2005, 22:28    Subject: Diagnostic Software: Solutions & Features Quote
Could someone please, please, please email me the older DOS version for Webasto?
[email protected]
Translated on 26-09-2026, 18:41.
messknecht
Post27-06-2005, 11:57    Subject: Webasto Heater Diagnostics: Online Software Found Quote
@ nibi123
What kind of Eberspächer do you have?
I could potentially look into D4WSC or D5WSC.
Upload the troubleshooting and repair guide.
If you have a modular clock or the TP5 remote control...
The errors displayed on the screen can be accessed using the following methods.
Based on the repair manual, I then found the description of what the error code means.
Sure! Please provide the text you would like me to translate from German to English.
Let me know if you need anything!
Gruß Messknecht!
Sharan 6.Gang BRT DPF
Mod.2008
Translated on 26-09-2026, 18:42.
hpralfi
Post19-08-2005, 12:03    Subject: Webasto Heater Diagnostics: Online Software Found Quote
Hello everyone!
Could someone please send me the DOS version of the Webasto software?
Thank you in advance.
[email protected]
best regards
Ralf.
Translated on 26-09-2026, 18:43.
Dutchman
Post27-01-2006, 23:48    Subject: Webasto Heater Diagnostics: Online Software Found Quote
Hello.
"Thank you!"
[email protected]
Fred.
Translated on 26-09-2026, 18:44.
megaonkel
Post31-01-2007, 1:35    Subject: Webasto Heater Diagnostics: Online Software Found Quote
Hi, does anyone know if it's possible to change the automatically generated 22°C target interior temperature during auxiliary heating operation using Webasto software? (This refers to an SH system originally installed in a Passat 3C).
No matter what temperature I had set previously, either in the seat heating or in the Climatronic system for the car's climate control, as soon as I activate the seat heating, it automatically sets the desired interior temperature to 22°C, and I would like to change that!
Thank you!
Post21-12-2010, 18:35    Subject: Webasto Heater Diagnostics: Online Software Found Quote
See diagnosis for retrofitted Webasto auxiliary heaters:
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 26-09-2026, 18:45.
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Malicious airbag manipulation using hacked diagnostic sof... On-Board Diagnostics (OBD)
No new posts High-Resolution Torque Specs Online? Diesel Engine Technology
No new posts VW Passat TDI: 96kW, 2WD, Webasto Heater Diesel Engine Technology
No new posts Webasto/ClimaTronic D1 Contact: Help Needed! Diesel Engine Technology
