Steering Column Electric Failure?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Stummel
Post31-12-2010, 11:29    Subject: Steering Column Electric Failure? Quote
Hello.
Okay, here's the translation:
'I had my 2010 Scirocco parked in the garage for a few days because I didn't need it. Yesterday, I got in, started it, and after driving a few kilometers, I tried to lower the volume on the steering wheel controls, but it didn't work?! I tried using the other controls on the steering wheel, but nothing happened... not even the horn works?! So, I connected VCDS and found this:'
Friday, December 31, 2010, 10:50:51:19924
VCDS Version: DRV 10.6.1
Data as of: 20100902.
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein.'
Vehicle type: 1K0
Scan: 01 02 03 08 09 10 14 15 16 17 18 19 25 42 44 46 47 52 56
Vehicle Identification Number: WVWZZZ13ZAVllll73
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
14-inch shock absorber -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: Error 0010.
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
56-Radio -- Status: OK 0000
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen.'
Address 01: Engine Control Module (CCZ)
Label file: 06J-907-115-CCZ.clb
Part number SW: 5K0 907 115, HW: 1K0 907 115 AA.
Component: 2.0l R4/4V TFSI 0040
Revision: AAH14--- Serial Number:
Encoding: 0403000C1C070060
Operating number: WSC 00020 790 00000
VCID: E7F26BA6AF1F
No error codes found.
Readiness: 0000 0000
Address 02: Transmission Label file: DRV\02E-300-0xx.lbl
Part number SW: 02E 300 053 B, HW: 02E 927 770 AL.
Part: GSG DSG AG6 511 2112
Revision: 51112 Serial Number: 00000912301458
Encoding: 0000020
Operating number: WSC 00020 000 90108
VCID: 1408EC6A4E09
'One error found:'
18275 - Data bus drive: Missing messages from the steering column electronics (J527).
P1867 - 000 - -
Environmental conditions:
Error status: 01100000
Error priority: 0
Lost Count: 40
Mileage: 14,897 km
Time: 0.
Date: 2010.14.11
Time: 00:01:23
Address 03: Brake electronics (J104)
Label file: DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Encoding: 743B60F5492500FD2E1006EB921C0041310000
VCID: 7AD4A2D24CAD
Address 08: Climate Control/Heater (J255)
Label file: 5K0-907-044.clb
Part number SW: 5K0 907 044 AM, Part number HW: 5K0 907 044 AM.
Component: Climatronic, Part Number: 130 0305.
Revision: 00002001
Encoding: 0000000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW36.rod
VCID: 76CCB6E278B5
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 086 C, HW: 5K0 937 086 C.
Component: BCM PQ35 M 011 0028
Revision: BC011001
Encoding: 40100A3890250A00408800801500012643293A88524D89605C8000000000
VCID: 34484CEA2E49
Part number: 1K8 955 119 D
Part: Wiper 20110 22 0614
Encoding: 009795
Address 10: Parking Assist 2 (J446) Label file: DRV\1K0-919-475.clb
Part number SW: 1K0 919 475 K, HW: 1K0 919 475 K.
Component: PARKING ASSIST 005 1706
Revision: 00005000 Serial number: 0 263 004 388
Encoding: 100101
Operating number: WSC 00020 790 393216
VCID: 3A5462D20C2D
Address 14: Wheel Dampening (J250)
Label file: DRV\3C0-907-376.clb
Part number SW: 3C0 907 376 A, HW: 3C0 907 376
Component: SOUND DAMPENING MATERIAL H07 0070
Revision: 00000000 Serial Number: 24120900900001
Coding: 000180
VCID: 2772ABA6EF9F
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 AE
Part number HW: 1K0 909 605 AE
Part number: 0G AIRBAG VW8, 020 2300.
Revision: 05020000 Serial Number: 003D1D020T7P
Coding: 0012359
VCID: 6FC2838607EF
Address 16: Steering wheel electronics (J527)
Label file: 5K0-953-569.clb
Part number SW: 5K0 953 521 D, HW: 5K0 953 569 A.
Component: STEERING MODULE 009 0122
Revision: FF010035 Serial Number: 20100115100175
Encoding: 1980040000
ASAM Dataset: EV_VW360SteerWheelUDS A01002
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 2D7E598ECD63
3 error codes found:
335876 - Data bus, drive: no communication.
U0002 00 [009] - No signal/communication.
Error status: 00000001
Error priority: 6
Error frequency: 1
Lost Count: 189
Mileage: 14,897 km
Date: 2010.14.11
Time: 10:41:31
1140738 - ROD - Unknown error code.
Error priority: 2
Error frequency: 1
Lost Count: 189
Mileage: 14,897 km
Date: 2010.14.11
Time: 10:41:31
1140741 - ROD - Unknown error code.
Error priority: 2
Error frequency: 1
Mileage: 0 km
Date: 2000-01-01
Time: 00:00:00
Address 17: Terminal block (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 1K8 920 871 B HW: 1K8 920 871 B
Component: KOMBI H05 0305
Serial number: 00000000000000
Encoding: 170900
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 314645FED15B
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.lbl
Part number: 1K0 815 007 BF
Component: Portable heater 021 3803
Revision: 00021000 Serial Number: 09011559000000
Encoding: 0001012
Operating number: WSC 00032 000 00000
VCID: 69F6ED9E390B
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530.lbl
Part number SW: 1K0 907 530 AD, HW: 1K0 907 951.
Component: J533, Gateway, H16 0233.
Revision: H16 Serial Number: 4520K10122129C
Encoding: EDA81F06100A02004000
VCID: 69F6ED9E390B
Address 25: Immobilizer (J334)
Label file: 5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Encoding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF41292BC0D
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MAX3.lbl
Part number SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Door seal 009 2123
Encoding: 0016437
VCID: 39567DDE092B
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x.lbl
Part number: 1K0 909 144 J
Component: EPS_ZFLS, Size 184, Part Number 3001.
Revision: 00H17000
VCID: 314645FED15B
'One error found:'
03803 - Steering angle sensor for power steering.
000 - - - Warning light ON.
Error status: 11100000
Error priority: 2
Error frequency: 1
Time: 0.
Battery voltage: 12.3 V
PD.
Temperature: 13.0°C
Quantity: 2
Steering angle: 0.00°
Quantity: 1
Lenkwi k.lnit.
Address 47: Soundsystem (R12) Label file: 5K0-035-456.clb
Part number SW: 5K0 035 456, HW: 5K0 035 456.
Component: Corporate Amplifier 8K H06.
Revision: -------- Serial Number: BP218198832368
ASAM Dataset: EV_AudioAmplifier8ChannelBNO1 A01003
ROD: EV_AudioAmplifier8ChannelBNO1_VW36.rod
VCID: E7F26BA6AF1F
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MAX3.lbl
Part number SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Encoding: 0016436
VCID: 3A5462D20C2D
Address 56: Radio (J0503) Label file: DRV\5M0-035-1xx-56.clb
Part number SW: 3C8 035 195 HW: 3C8 035 195
Part: Radio RCD510, part number 040 0166.
Revision: 00000001 Serial Number: VWZ1Z3K6348503
Encoding: 0501000001
VCID: E5EE61AE5513
End.
^^ I tried to clear the errors, but it didn't work... So I disconnected the battery, waited 5 minutes, and reconnected it. But that didn't help either; now there's an error message about the steering angle sensor. It looks like it might be a job for the workshop, doesn't it?
Marc
Translated on 28-10-2026, 10:45.
