AGR & KAT: Understanding and Implementation
SST
Post28-05-2002, 23:38    Subject: AGR & KAT: Understanding and Implementation Quote
Does deactivating the AGR (Abgasrückführung) actually have any negative consequences?
What about the cat?
Translated on 12-10-2026, 17:54.
SST
Post31-05-2002, 14:46    Subject: AGR & KAT: Understanding and Implementation Quote
Oops, it seems like nobody knows the answer to that question.
Post31-05-2002, 15:35    Subject: At least it's not a practical problem... Quote
Hi.
If driving without an EGR system is already considered "illegal" and the emissions test (ASU) is less problematic without it than with it, why should the proper functioning of the catalytic converter cause any headaches?
Based on my assessment, the catalytic converter should not be damaged, meaning that after activating the EGR system, it should function as it did before.
But it won't be checked, as long as the diesel emissions test only focuses on the particulate matter (PM) level.
Translated on 12-10-2026, 17:55.
SST
Post03-06-2002, 7:59    Subject: AGR & KAT: Understanding and Implementation Quote
I didn't know that either. Does that mean if I replace the catalytic converter with a dummy one, it won't even be noticed during the inspection?
Translated on 12-10-2026, 17:56.
Post03-06-2002, 15:39    Subject: Kat AU: Your Guide to German Labor Law Quote
I didn't know that either; that means if I replace the cat with a fake cat, it won't even be noticed during the inspection?
As long as the inspector only focuses on the k-value and not on factors like noise, that might be the case.
Translated on 12-10-2026, 17:57.
Post03-06-2002, 15:41    Subject: Kat AU: Your Guide to German Labor Law Quote
As far as I can (theoretically) estimate, that's correct - as long as the inspector only focuses on the k-value and not on the noise.
If you're hoping to get more performance out of it: several people have probably already tried that, without success. Occasionally, something is written about it here.
Translated on 12-10-2026, 17:58.
