Audi A3 8P: Remote Unlock & Keyless Entry
Moony
Location: In einen kleinen unbekannten Dorf am A. der Welt in Österreich
Post29-01-2011, 21:03    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
Hey everyone,
I'm looking for a coding solution for my A3 8P, manufactured in 2007...
Here's the translation:
"Here's what I want:"
When I drive at approximately 15 km/h, the vehicle automatically locks (Auto Lock) - and that is intentional.
But... I want it so that when I open, for example, the driver's door, ALL the doors unlock again! Not only after the key is removed from the ignition.
Because I've gotten out so many times, and I wanted to unload something from the trunk... but it was still locked! icon_evil.gif
Is there a coding for that? icon_question.gif icon_question.gif icon_question.gif
I couldn't find the right information on openbd.org, or I'm not sure which code would be the correct one.
Translated on 18-10-2026, 2:19.
Post29-01-2011, 21:20    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
Honestly, I don't think what you want can be changed through coding. Doesn't your door have an "everything on/off" button? Surely it does, and there should be a key painted on it. icon_wink.gif
Translated on 18-10-2026, 2:20.
speedjunkie
Post29-01-2011, 23:28    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
I've been looking for a solution to this problem for over half a year now, because I keep forgetting to press the button on the driver's door, and it's really annoying sometimes, especially when I'm already stressed.
BMW 325tds
Translated on 18-10-2026, 2:21.
Moony
Post06-02-2011, 14:42    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
I hope there's a solution... because the button on the driver's door is only connected to a control unit (ECU), right? There must be a way to access or control it somehow?!
Best regards, Thomas.
Audi A3 8P Sportback 2.0 TDI Quattro S-Line 2007
voodoo
Post06-02-2011, 16:52    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
Not without a little tinkering...
As far as I know, it is not encodable.
I've searched for a solution multiple times, but I haven't found anything (on my A4 8E, and also on a friend's A3 8P).
It doesn't really make sense when you think about the function that the autolock is supposed to serve.
The anti-hijacking function (autolock) is designed to prevent people from opening the vehicle from the outside without your consent.
Translated on 18-10-2026, 2:22.
speedjunkie
Post06-02-2011, 17:08    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
I cannot confirm that.
It is certainly true that the autolock feature provides protection against carjacking, but it is still possible, in other brands of cars, that when you open the driver's door, all other doors and hatches will also unlock.
If the driver's door is already open, it probably doesn't matter whether the rest of the car is locked or not in terms of hijacking, because a hijacker would likely choose the open driver's door over a closed one.
BMW 325tds
Translated on 18-10-2026, 2:24.
voodoo
Post06-02-2011, 17:18    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
I see it a bit differently.
I've witnessed something similar happening live in Spain before.
You're standing at the parking meter and need to open the door (you didn't park close enough).
At that moment, a passerby approaches and tries to open the trunk or the rear door.
And as a driver, you're powerless; by the time you realize what's happening, the thief is already gone.
Therefore, in my opinion, it makes sense that the vehicle is only unlocked when the driver wants it to be, either by turning the key or by pressing the unlock button.
And P.S. Humans are creatures of habit. If you open the door, you might also get used to pressing the button.
And for those who can't accept that, they can build a small circuit that automatically unlocks the vehicle when the driver's door is opened with the ignition on.
Translated on 18-10-2026, 2:25.
speedjunkie
Moony likes this.
Post06-02-2011, 17:51    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
voodoo wrote:
And for those who cannot accept this, they can build a small circuit that automatically unlocks the vehicle when the driver's door is opened with the ignition on.
That's the point of this topic: to find a solution!
BMW 325tds
Translated on 18-10-2026, 2:27.
michiglaser
2007 Audi A4 Avant
Post06-02-2011, 17:53    Subject: Audi A3 8P: Remote Unlock & Keyless Entry Quote
voodoo wrote:
I have searched multiple times for a way to do this, and I haven't found anything (on my A4 8E, and on a friend's A3 8P).
That works on my 2007 A4.
Why shouldn't it work on yours?
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Touran: Transfer log files to laptop On-Board Diagnostics (OBD)
No new posts Audi B4 Interface: Compatible with Shop? On-Board Diagnostics (OBD)
No new posts How do I winterize my TDI? Transmission, Chassis, Body & Interior
No new posts Passat 35i Dryer: Replacement for 3A5, 1996 Transmission, Chassis, Body & Interior
