Engine Control Unit Errors: 2.5L V6 TDI (No Delete) (Solution)
Post07-02-2011, 21:10    Subject: Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Quote
When reading the diagnostic trouble codes from various 2.5L V6 TDI engines, the following non-erasable errors are found in the engine control unit:
01318 - Control unit for fuel injection pump (J399) 34-00 - No fault code detected.
Cause: Software error in the engine control unit.
Remedy:
- Possibly search for radio codes/PINs, etc.
- Disconnect the vehicle battery.
- Wait 5 minutes.
- Access the engine control unit (ECU) using VCDS and clear the fault memory.
Translated on 12-10-2026, 6:04.
Ratings - Engine Control Unit Errors: 2.5L V6 TDI (No Delete)
No new posts Document Touran, Error in Comfort System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, valid until 06/2000, issue with defroster... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intermittent fault: Engine control unit and pump-nozzle v... Diesel Engine Technology
No new posts Engine Control Unit Locked: Troubleshooting Guide Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
