Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
08-02-2011, 9:17 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
Good morning.
Here's the translation:
"This is about the following vehicle:"
Ford Galaxy, engine code AHU, TDI diesel, registration letter "AHU", manufactured in 1998.
The old MSG has a fault in the altitude sensor (which cannot be fixed by replacing it or using a voltage divider) and needs to be replaced. I obtained one from a Galaxy manufactured in 1996, and I want to adapt it to my 1551 for use with the WFS:
Address: 25
Function 10.
Channel 00: Delete learning values --> Yes.
Function 06: Exit and turn off the ignition.
The vehicle starts briefly but immediately shuts off again, even after repeated attempts.
If I reinstall the defective MSG (Modular Service Interface), it will also be locked. However, this procedure of pairing the WFS (Wireless Front System) works perfectly there; the engine starts and stays running.
I tried to delete the learning values in the MSG, but when I confirm it, I get the message: "Function not possible..."
Where could the problem be?
Thank you for your help.
Ruedi. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 29-07-2026, 3:35.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
08-02-2011, 10:24 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
Is the part number of the "new" engine control unit (ECU) identical to the old one?
Translated on 29-07-2026, 3:37.
Profile PM WWW Garage |
08-02-2011, 11:52 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
Hi.
It has a different index; instead of "HC" like the old one, it uses "P".
"I took this out of a wrecked 1996 Galaxy with an AHU engine, which the scrap dealer said was still running. I can take it back if it doesn't fit, but unfortunately, he doesn't have any other options."
Best regards, Rüdi. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
08-02-2011, 12:22 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
"How can I find out the version number? My English isn't very good."
I only know that the WFS control unit is a separate component located under the MSG (presumably an abbreviation for another part).
Would this number be helpful to them?
I cannot provide any data for Linz; I am currently using an older version from 1551. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 29-07-2026, 3:39.
Profile PM Garage |
08-02-2011, 12:56 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
Translated on 29-07-2026, 3:40.
08-02-2011, 13:00 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
We only bought the car two weeks ago, and it came with nothing but two keys; the previous owner didn't include anything else. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
mullemaus Guest
09-02-2011, 0:01 Subject: Immobilizer: Engine Control Unit (ECU) Not Learning |
How can I find out the version, my English is not very good.
I only know that the WFS control unit is a separate component located under the MSG (presumably referring to a specific module or system).
I cannot provide Linz data; I am working with an old version from 1551.
Yes, the number might be helpful if needed  .
Translated on 29-07-2026, 3:41.
