Deus Violentia Schrauber
21-04-2011, 20:39 Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? |
In short: Is there a 240mm electronic motor shortening (EMS) system for VW/Audi that is compatible with the power output of a 2.0 TDI engine? BKD GRF
AHF EBF
Translated on 21-08-2026, 12:32.
Fab176 Blaumann
Joined: 05/27/2006 Posts: 27 Karma: +1 / -1 Location: Minden 2000 Volkswagen Golf Premium Support
22-04-2011, 11:50 Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? |
I have a 240mm Sachs EMS clutch installed on my 2.0 TDI engine. Sachs also offers a more powerful clutch that is designed to fit it. However, I cannot determine whether or not this meets the criteria of being "original" equipment. It's definitely not from SPEC or a similar brand.
Fabian. VW Golf 4 TDI 4motion
Translated on 21-08-2026, 12:33.
Profile PM Garage |
27-04-2011, 11:34 Subject: EMS 240mm for 2.0 TDI 16V BKD: Original? |
Do you use a sprung or rigid friction disc?
Question for everyone: Is applying "starr" (presumably referring to a specific setting or mode) always considered detrimental to the transmission and drivetrain, or only when you disable the brain and engage in full-power, binary coupling? BKD GRF
AHF EBF
