AFN Bremspedal Einfluss auf Gaspoti? | Posts 16+
Go to page: Previous  1, 2
Wiesel
Post03-07-2011, 23:11    Subject: Quote
frebert wrote:
@ Wiesel: I don't have a climate! PIN 37 on the MSG is not assigned to me.
and there is also no moisture / green flakes etc. in that area on the connector?!
frebert
Post04-07-2011, 13:25    Subject: Quote
and there is also no moisture / green span etc. in that area?!
No way! I'm betting on the coolant temperature sensor; it might be about to fail, and that's the first sign. Next time, when the RPMs go up again, I'll replace it.
1,9 l AFN mit Schick Wasser LLK im T3
Post04-07-2011, 15:37    Subject: Quote
frebert wrote:
Could someone perhaps tell me what factors might affect the LL (Low Load) engine speed when the engine and fuel pump are functioning correctly?
Again: The coolant sensor is a dual sensor. Compare what he shows in STG 01 and 17.
The donor frequently goes to the reeds, so there is a certain probability.
If the coolant exchange (!) doesn't yield any results, it could also be due to leaking oil from a faulty cooler. Are you experiencing a massive increase in oil consumption? Does he experience "high-level emptiness" as described?
Post04-07-2011, 15:41    Subject: Quote
frebert
Post04-07-2011, 18:19    Subject: Quote
Again: The coolant valve is a double valve. Compare what he shows in STG 01 and 17.
STG value matches 90°C, and my analog temperature display is also in its usual position.
Turbo can be ruled out.
No new posts AGR Impact on Engine Efficiency Diesel Engine Technology
No new posts Gaspoti Connectors: Types & Compatibility Diesel Engine Technology
No new posts Ansteuerdauer + Kalibrierdrücke, Einfluss von Chiptuning? Diesel Engine Technology
No new posts Problems after installing a Golf IV gas stove on a 1Z Diesel Engine Technology
