Passat 3B: 5- to 6-Speed Conversion - Easy?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
karlstein12
Post16-07-2011, 22:19    Subject: Passat 3B: 5- to 6-Speed Conversion - Easy? Quote
"In my Passat 3B (3/2000 / ATJ), the third gear has been making a very noticeable grinding noise when shifting since yesterday. (Transmission EYZ). Especially when downshifting into third gear, there's a very unpleasant noise without double-clutching.'icon_sad.gif'"
Most likely, the timing ring has broken, as the error appeared suddenly.
I'm now considering installing a used gearbox and I want to know if a 6-speed gearbox (e.g., ELN, ELP, EHW) can be used instead of the EYZ 5-speed gearbox. The gearboxes mentioned should all have the same housing and the same shift pattern (reverse gear on the left, front).
My question is, is this a "plug and play" solution, or does the conversion from a 5-speed to a 6-speed transmission also require a different shift linkage or something similar?
Greetings.
Rupert.
Translated on 13-09-2026, 19:45.
karlstein12
Post18-07-2011, 20:19    Subject: Passat 3B: 5- to 6-Speed Conversion - Easy? Quote
"Is it really the case that nobody knows this?"
or should I move the question to a different forum?
Greetings.
Rupert.
Translated on 13-09-2026, 19:46.
mullemaus
Post18-07-2011, 20:21    Subject: Passat 3B: 5- to 6-Speed Conversion - Easy? Quote
5-speed, 228mm clutch.
6-speed, 240mm clutch.
6-speed - intermediate plate and other starter/flywheel etc. etc. icon_cool.gif
Translated on 13-09-2026, 19:47.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Probleme mit Ulfs plug and play adapter Diesel Engine Technology
No new posts 5-to-6 Speed Conversion: Upgrade Your Gearbox Transmission, Chassis, Body & Interior
No new posts Light warning buzzer no longer works after renovation KI Transmission, Chassis, Body & Interior
No new posts Gear Shift Problem: 5th Gear Not Engaging Transmission, Chassis, Body & Interior
