HB4 ab Werk blind ! | Posts 16+
Go to page: Previous  1, 2
Karma: +1100 / -0   Thank you, like it!
Post28-03-2011, 11:48    Subject: Quote
It might be possible to conduct an (obviously non-representative) experiment with new lamps from a different manufacturer to "see" what happens. By the way, I've also seen something similar in some company Tourans, and to my knowledge, those didn't have cornering lights.
Translated on 14-09-2026, 4:04.
Post28-03-2011, 11:50    Subject: Quote
Here's the translation:
"As a supplement: The glass covers in front of the round G6 auxiliary lights seem to break surprisingly often, as one reads about it online. Is there a connection between this and the discolored glass bulbs (due to overheating)?"
Translated on 14-09-2026, 4:05.
Post28-03-2011, 12:17    Subject: Quote
Lucky you, no turn signals needed.
I think I'm going to remove the turn signals on the G5 again - the reflector shape makes it more of a visual gimmick than anything useful. However, they are actually useful on the G6.
Post28-03-2011, 12:47    Subject: Quote
dieselmartin wrote:
You lucky person who never has to take a detour.
"I also coded them to work without the approval mark. It does make a difference, although 35W won't turn night into day. I mostly keep the cornering lights off to avoid unnecessarily stressing the actuators. They only come on on country roads, which is easily done via the MFA (Multi-Function Display). I don't want to have to replace two SW (steering wheel module) housings someday because of defective actuators."
Translated on 14-09-2026, 4:06.
Post28-03-2011, 13:00    Subject: Quote
It's strange that 3C and G6+ can't disable that.
Translated on 14-09-2026, 4:07.
captaindickei
Karma: +1 / -1   Thank you, like it!
Post06-07-2011, 10:45    Subject: Quote
Roger wrote:
dieselmartin wrote:
You lucky person who didn't get into an accident while turning.
Why, I also coded them to work without the checkmark. It does make a difference, although 35W doesn't turn night into day. I mostly keep the cornering light off to avoid unnecessarily stressing the actuators. They are only active on country roads, which can be easily toggled via the MFA. I don't want to have to replace two SW housings someday because of defective actuators.
So, you don't need to worry about that. You can easily get 200,000 km with a Q7, and with the xenon headlights and cornering lights always active. There are absolutely no problems with the cornering lights or the bulbs icon_wink.gif.
"Automatic headlight leveling is a feature found on all vehicles with xenon headlights, and you rarely hear about any problems with the actuators."
Translated on 14-09-2026, 4:08.
Post06-07-2011, 10:56    Subject: Quote
Your words in VW's ears.
"This piece of junk cost me 300 EUR: The tilting module and the shutter weren't compatible, and at a certain angle of the swivel light, the shutter would fall off -> I had to replace the entire housing, and they only offered a partial discount, all this after just 2.5 years of use!!!"
Furthermore, an automatic low beam headlight system (required for xenon headlights) is not the same as a dynamic low beam headlight system.
Translated on 14-09-2026, 4:10.
Octavia_4x4
Post06-07-2011, 13:25    Subject: Quote
Recently, I had a new Ibiza 6J, also with cornering lights. To my surprise, the bulbs looked exactly the same. And that after only 8,000 km...
Post06-07-2011, 13:36    Subject: Quote
I already mentioned that I noticed this on brand new Tourans without (any) xenon headlights or cornering lights, specifically regarding the bulbs in the fog lights.
Translated on 14-09-2026, 4:11.
Post19-07-2011, 10:44    Subject: Quote
Ford Mondeo, S-Max, ... icon_eek.gif The headlights of the fog lights, as well as those in the high beams, are equipped with milky yellow/brown halogen bulbs. The vehicles are all very new to brand new.
No new posts Golf 3 Mirror Glass - Blind Spot View Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vintage Valve Adjustment: Factory Secrets Diesel Engine Technology
No new posts How is the factory-installed AHK (trailer hitch) wired? Diesel Engine Technology
No new posts Tuning: Factory vs. Aftermarket & FAQs Diesel Engine Technology
No new posts Are rear door speaker wires already pre-installed in the G4? Transmission, Chassis, Body & Interior
