I would like to retrofit my Seat Altea with bi-xenon headlights including cornering lights. Okay, I now need the correct encoding for the AFS control unit and the power modules.
Can someone help me with this?
VCDS Version: RKS 10.6.3
Data as of: 20110306.
Monday, May 2, 2011, 18:01:33:12405
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 62 69 72 7D
Vehicle Identification Number: VSSZZZ5PZ6R018405 Mileage: 148,390 km
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000
55-Beam adjustment. -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
69-inch cable -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 HE HW: 028 101 229 1
Part: R4 2.0L EDC G000SG 7000
Revision: 12345678 Serial number: SEZ7Z0E3107016
Encoding: 0050072
Operating number: WSC 06402 785 00200
VCID: 6DD59EA40D17
No errors found.
Readiness: 0 0 1 1 1
Address 03: Brakes Label file: RKS\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Encoding: 0006898
VCID: 408B17106A05
No errors found.
Address 08: Climate/Heating Label file: RKS\1K0-907-044.lbl
Part number: 5P0 907 044 B
Part number: Climatronic PQ35 006 0203
Operating Number: WSC 00000 000 00000
VCID: 2F6944ACC79B
No errors found.
Address 09: Body Control Module
Label file: RKS\3C0-937-049-30-H.lbl
Part number SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: On-board network module H54 2202.
Revision: 00H54000 Serial Number: 01000007592409
Encoding: A3884E0700000000102D0000000000000009FD0B0040010C000000000000
Operating number: WSC 35110 377 08192
VCID: 71ED82D4112F
Part number: 5P0 955 119 B.
Part: Wiper SE359 012 0402
Encoding: 00056272
No errors found.
Address 15: Airbag
Label file: RKS\1K0-909-605.lbl
Part number SW: 1K0 909 605 N, Hardware number: 1K0 909 605 N.
Part: S3 AIRBAG VW8 015 2100
Revision: 03015000 Serial Number: 0038ED0GJN9J
Encoding: 0021299
VCID: 37797CCC3FCB
No errors found.
Address 16: Steering wheel
Label file: RKS\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AG Hardware number: 1K0 953 549 AG
Part: J0527 034 0070
Encoding: 0002042
VCID: 77F9BCCC7F4B
Part number: XXXXXXXXXXX
Part: E0221 004 0060
No errors found.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.lbl
Part number: 5P0 920 823 B
Component: COMBINATION INSTRUMENT VO3 0616
Encoding: 0004101
Operating number: WSC 93103 474 95794
VCID: 2F6944ACC79B
No errors found.
Address 19: CAN-Gateway Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120.
Revision: H10
Serial number: 2800105625952C
Encoding: 7D3F4B00078202
VCID: 2A5F55B8FC79
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Component: IMMO VO3 0616
VCID: 2F6944ACC79B
No errors found.
Address 42: Door electronics. Driver Label file: RKS\1K0-959-701-MAX2.lbl
Part number: 1T0 959 701 C.
Part: Door Seal 024 2431
Encoding: 0000144
VCID: 37797CCC3FCB
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K1 909 144 J.
Component: EPS_ZFLS, Class 5, D04 1606.
VCID: 326F4DD8D4A9
No errors found.
Address 46: Comfort System
Label file: RKS\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AK
Component: KSG 0401
Encoding: 18D000D82D000505084F090000CC
Operating number: WSC 33103 476 07781
VCID: 79FDBAF4495F
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
No errors found.
Address 52: Door electric, passenger side. Label file: RKS\1K0-959-702-MAX2.lbl
Part number: 1T0 959 702 C
Encoding: 0000144
VCID: 387B7FF032D5
No errors found.
Address 55: Headlight range adjustment. Label file: RKS\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 C. Hardware: 5M0 907 357 C.
Component: AFS Control Unit 0142
Revision: 00H04000 Serial Number:
Encoding: 1180802
Operating number: WSC 01316 111 20184
VCID: 34634BC02EBD
Part number: 7L6 941 329 A
Component: AFS-Lst. Module l 0004
Encoding: 00000035
Part number: 7L6 941 330.
Component: AFS-Lst. module r X018
Encoding: 00000034
4 errors found:
01042 - Control unit not coded.
000 - - - Warning light ON.
Environmental conditions:
Error status: 11100000
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
02656 - Headlight module, left side (J667), not coded.
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
02657 - Headlight module, right side (J668)), not coded.
Error priority: 2
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
01539 - Headlights not adjusted.
005 - No or incorrect initial setting/adaptation - Warning light ON.
Error status: 11100101
Error priority: 3.
Error frequency: 1
Lost Count: 131
Time: 0
invalid
invalid
invalid
Address 62: Door opener, left and right. Label file: RKS\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E.
Component: Door Seal 021 2426
Encoding: 0000144
VCID: 326F4DD8D4A9
No errors found.
Address 69: Trailer (J345) Label file: RKS\1K0-907-383-MY8.lbl
Part number SW: 1K0 907 383 F, HW: 1K0 907 383 F.
Part: Trailer H09 0100
Revision: 3A001001 Serial Number: 00000144953027
Encoding: 0100000100000000
VCID: 306B47D0DAA5
No errors found.
Address 72: Door opener, right side. Label file: RKS\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
VCID: 336148DC2BB3
No errors found.
Address 7D: Auxiliary Heater
Label file: RKS\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial Number:
VCID: 2D555EA4CD97
No errors found.
End.
