VCDS / Address 37: Navigation not accessible
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Azrael666
2006 Audi A3
Registered VCDS User
Post11-08-2011, 16:46    Subject: VCDS / Address 37: Navigation not accessible Quote
Hey everyone,
I'm having a small problem with my navigation system (BNS 4.x), and I can't access it using VCDS. The message "Navigation not reachable" always appears.
Okay, so the navigation system is definitely there; I can see it and use it, after all.
I am using VCDS version 10.06.4 and the Micro-CAN interface.
Does anyone have any idea what might be causing this?
PS: The scan is a bit older, but I'm still getting the same error with the new version.
Tuesday, March 1, 2011, 3:57:54:19517
VCDS Version: RKS 10.6.3
Data as of: 20101206
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 7D
Vehicle Identification Number: WAUZZZ Mileage: 153,500 km
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\03G-906-021-BMM.lbl
Part number SW: 03G 906 021 GL, HW: 028 101 223 4.
Part: R4 2.0L EDC G000SG 8411
Revision: --H01--- Serial Number: AUX7Z0F1FND0TB
Encoding: 0000072
Operating number: WSC 06314 000 00000
VCID: 6FC283C2071B
No errors found.
Readiness: 0 0 0 0 0
Address 03: Brakes Label file: RKS\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AA, Hardware number: 1K0 907 379 AA.
Component: ESP FRONT MK60 0102
Revision: 00H13001
Encoding: 0006786
VCID: 71C685BA112F
No errors found.
Address 08: Climate Control/Heating Label file: RKS\8P0-820-043.lbl
Part number SW: 8P0 820 043 N HW: 8P0 820 043 N
Component: Climate Control System H18 0260.
Revision: 092622 Serial Number: 8P0820043N
VCID: 37527BA23FCB
No errors found.
Address 09: Body Control
Label file: RKS\8P0-907-279-23-H.lbl
Part number SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: On-board network module H43 1201.
Revision: 00H43000 Serial Number: 00000005478082
Encoding: 05884F019214100000160000160000000008FE175C0100
Operating number: WSC 06314 000 08192
VCID: 40A0107E6A05
Part number: 8P1 955 119 B
Component: Wiper AU350 H01 0130
Encoding: 00062736
No errors found.
Address 15: Airbag
Label file: RKS\8P0-959-655-94.lbl
Part number SW: 8P0 959 655 C. Hardware: 8P0 959 655 C.
Part: Airbag 9.41 H12 3760
Revision: 91H12376 Serial Number: 00362006DZR6
Encoding: 0070612
VCID: 42A41A766409
No errors found.
Address 16: Steering wheel
Label file: RKS\8P0-953-549-F.lbl
Part number SW: 8P0 953 549 F HW: 8P0 953 549 F
Part: J0527 H34 0070
Encoding: 0000042
VCID: 41A6157A610F
No errors found.
Address 17: Instrument Cluster
Label file: RKS\8P0-920-xxx-17-MY7.lbl
Part number SW: 8P0 920 930 R HW: 8P0 920 930 R
Component: COMBINATION INSTRUMENT. VDO H80 0420
Revision: D06 Serial Number: 2241FD06077215
Encoding: 0004013
Operating number: WSC 60040 176 61635
VCID: 41A6157A610F
No errors found.
Address 19: CAN-Gateway Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 G, HW: 1K0 907 951.
Component: J533__Gateway H10 0140
Revision: H10 Serial Number: 300010613183F7
Encoding: 3D3F0B4A07002102
VCID: 2B7A57D2F383
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Revision: D06 Serial Number: AUX7Z0F1FND0TB
Operating Number: WSC 00000 000 00000
VCID: 41A6157A610F
No errors found.
Address 37: Navigation.
unavailable
Address 42: Door electronics. Driver Label file: 8P0-959-801-MIN2.lbl
Part number: 8P0 959 801 H
Component: Door Seal 020 0090
Encoding: 0000216
VCID: 40A0107E6A05
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K1 909 144 K
Component: EPS_ZFLS, Class 5, D06 1701.
VCID: 334A4FB22BB3
No errors found.
Address 46: Comfort System
Label file: RKS\8P0-959-433.lbl
Part number: 8P0 959 433 E
Component: KSG, H04 0050.
Encoding: 188000186D088505488F016300
VCID: 3E5C6E8610F1
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
No errors found.
Address 47: Soundsystem Label file: RKS\8Px-035-382.lbl
Part number SW: 8P4 035 382 Part number HW: 8P4 035 382
Component: AB2 SUBWOOFER BOX H04 0180
Revision: 00003 Serial number: 30674548399400
VCID: F1C605BA912F
No errors found.
Address 52: Door electric, passenger side. Label file: 8P0-959-802-MIN2.lbl
Part number: 8P0 959 802 H
Encoding: 0000216
VCID: 41A6157A610F
No errors found.
Address 56: Radio Label file: RKS\8P0-035-1xx-56.lbl
Part number SW: 8P0 035 186 C, HW: 8P0 035 186 C.
Part number: concert II EU H52 0100.
Revision: 02S Serial Number: AUZ2Z3F3586696
Encoding: 0001011
Operating number: WSC 06435 000 00000
VCID: 32444AB6D4A9
No errors found.
Address 62: Door opener, left and right. Label file: RKS\8P4-959-801.lbl
Part number: 8P4 959 801 D
Part: Door Seal 020 0070
Encoding: 0000216
VCID: 40A0107E6A05
No errors found.
Address 72: Door opener, right side. Label file: RKS\8P4-959-802.lbl
Part number: 8P4 959 802 D
Encoding: 0000216
VCID: 41A6157A610F
No errors found.
Address 7D: Auxiliary Heater
Label file: RKS\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial Number:
VCID: 2D7E59CACD97
No errors found.
End.
Audi A3 8P 2.0TDI 140PS BMM / BJ.2006 / 164000km
Translated on 05-07-2026, 17:22.
Post11-08-2011, 16:55    Subject: VCDS / Address 37: Navigation not accessible Quote
Original navigation system or aftermarket?
When retrofitted, is the wiring completely and correctly connected? Is it configured in the gateway (address 09)?
Translated on 05-07-2026, 17:42.
Azrael666
2006 Audi A3
Post11-08-2011, 17:36    Subject: VCDS / Address 37: Navigation not accessible Quote
Hmm, that's a good question. I bought the car used, and the navigation system was already installed. According to myAudi, where I registered using the vehicle identification number, the navigation system is listed under "Special Equipment."
Features: Ambition.
Model-specific standard equipment for the A3 Sportback Ambition.
Aesthetic differentiation within:
- High-gloss decorative inlays, in door panels and center console.
- Door sills with aluminum trim.
- Upholstery in Matrix fabric.
Aesthetic differentiation on the exterior:
- Aluminum alloy cast wheels with a 5-arm design, size 7.5 J x 17, with tires 225/45 R 17.
Functional differentiation:
- Front passenger seat height adjustable.
- Driver information system including radio clock.
- Fog lights, halogen, integrated into the front bumper.
- Sunshade for the rear window.
- Sport suspension (also available with standard suspension).
- Sport steering wheel in a 3-spoke design, including. Gear knob, gear lever boot, and handbrake lever, all in leather.
- Sports seats in the front.
6-speed manual transmission.
fully synchronized
Interior lighting package.
Illuminated door handles, front footwell lighting, entry lighting, illuminated vanity mirrors, illuminated storage compartment in the center console, front and rear reading lights, ambient lighting, active door reflectors.
Spare tire, space-saving.
Roof railing, anodized aluminum.
With a novel design; for secure transportation, it is one-piece and seamless, stable and aerodynamic, emphasizing the coupé-like roofline; made of anodized aluminum.
Heated seats for the driver and passenger, with separate controls.
Heated seat surfaces, bolsters (for leather upholstery), and backrests, with multi-level individual adjustment for each seat; particularly comfortable in winter and with leather upholstery.
Front center armrest.
for drivers and passengers, with a tilting storage compartment, adjustable in angle.
Tire pressure monitoring system.
The system monitors the tire pressure set by the driver and transmitted to the system via the controls during the ride. If a tire loses air pressure, the tire pressure monitoring system calculates the air loss based on the difference in rotation speed and alerts the driver visually and audibly.
The system does not exempt you from regularly checking the tire pressure.
CD-ROM for Germany.
Navigation system.
Speed control system.
Maintains a constant speed of approximately 30 km/h, as far as the motor power or motor braking effect allows; controlled via a separate handlebar lever.
Comfort climate control.
FCKW-free, with solar-dependent control, selectable control independently for driver and passenger sides; electronically regulates air temperature, volume, and distribution; automatic recirculation mode with filtration of the cabin air by an air quality sensor, activated carbon filter, and pollen filter; key recognition.
Lighters and ashtrays.
in the central console.
I can't say for sure right now whether it's registered in the STG 09 system; I would need to check that.
Translated on 05-07-2026, 17:46.
Azrael666
2006 Audi A3
Post16-08-2011, 16:09    Subject: VCDS / Address 37: Navigation not accessible Quote
Okay, I checked with VCDS. The navigation system is listed in the parts list under the CAN gateway. It is also registered in the radio control unit (coding icon_smile_thumb_up.gif).
Translated on 05-07-2026, 17:50.
Post16-08-2011, 16:46    Subject: VCDS / Address 37: Navigation not accessible Quote
suspect, could it be that an exception applies to this navigation system, and that it can be accessed via the K-Line?
Someone from the forum might be nearby with a professional system (KKL+CAN) and could quickly connect to your vehicle.
Translated on 05-07-2026, 17:51.
Azrael666
2006 Audi A3
Post16-08-2011, 16:59    Subject: VCDS / Address 37: Navigation not accessible Quote
Hmm, the idea makes sense, considering I only have the Micro-CAN. Would it make sense if Audi connected via the K-line and the radio via CAN?
Post16-08-2011, 17:51    Subject: VCDS / Address 37: Navigation not accessible Quote
Azrael666 wrote:
hmm, the idea is obvious, since I only have the Micro-CAN. Would it make sense if Audi connected via K-Line and the radio connected via CAN?
It's not necessarily about the brand, but I seem to remember reading something about K-Line cables for that type, so trying it out would probably be the easiest thing to do.
A small consolation regarding the current situation: Whether there was an error or not would also be displayed in the overview by the gateway, but it wouldn't specify what type of error it was.
Translated on 05-07-2026, 17:52.
voodoo
Post17-08-2011, 8:48    Subject: VCDS / Address 37: Navigation not accessible Quote
The RNS-E can only be accessed via the K-line.
You don't stand a chance with the Micro-Can.
Reason: The RNS-E originates from the A4 8E B6 and the A6 4B models and was introduced as early as the year 2003.
However, Audi only started making STGs (Steuergeräte, or control units) CAN-bus diagnosable in 2005.
Even my 2007 B7 model still has 90% of its control units that can be accessed via the K-line.
Only the MSG is accessed via CAN.
Translated on 05-07-2026, 17:53.
Deus Violentia
Post17-08-2011, 9:50    Subject: VCDS / Address 37: Navigation not accessible Quote
The RNS-E can definitely be accessed via CAN, it's just a matter of coding it to the appropriate vehicle! He doesn't have the RNS-E system here, but rather a Concert II radio.
The diagnosis for the BNS is performed via the K-line, and, well, it's kind of like voodoo, but he has the BNS4.0 icon_wink.gif.
Do not confuse this - the BNS 4.0 is an external device with a navigation computer and display via the FIS (fahrzeugintegrierte Schnittstelle - integrated vehicle interface).
The solution is the one that Rainer suspects - the K-Line interface! icon_biggrin.gif
BKD GRF
AHF EBF
Translated on 05-07-2026, 17:55.
Azrael666
2006 Audi A3
Post17-08-2011, 11:38    Subject: VCDS / Address 37: Navigation not accessible Quote
Yes, that's right, the BNS4.0 is the navigation system installed in my car. Hmm, it's definitely annoying that this thing can only be accessed via the K-line. That explains why the Micro-CAN isn't getting a connection.
I probably should have invested in the "larger" interface icon_sad.gif instead.
Sure, here's the translation:
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English.
Translated on 05-07-2026, 17:56.
Deus Violentia
Post17-08-2011, 11:40    Subject: VCDS / Address 37: Navigation not accessible Quote
Perhaps Rainer offers a "Upgrade" option by accepting the return of the current hardware plus an additional payment?
BKD GRF
AHF EBF
Translated on 05-07-2026, 17:57.
Azrael666
2006 Audi A3
Post18-08-2011, 7:54    Subject: VCDS / Address 37: Navigation not accessible Quote
Hmm, that would be great, of course. My Micro-CAN is now about icon_smile.gif n 3/4 of a year old, and I always keep it safely in the dresser drawer .
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering column lock inaccessible Electrical Systems, Vehicle Electronics, Multimedia
No new posts A7 4K: Control units unreachable & data bus errors On-Board Diagnostics (OBD)
No new posts HEX-NET Firmware update Server not reachable On-Board Diagnostics (OBD)
No new posts Control Unit 46: Suddenly Unreachable? On-Board Diagnostics (OBD)
