S6 4A Treadmill System 1791
chriskross
Post18-08-2011, 17:38    Subject: S6 4A Treadmill System 1791 Quote
Hello.
I have a S6 with engine code 4A. AHK V8
Error 17916: Idle system learning value has reached the upper limit.
I read that it's supposed to help recalibrate the throttle.
Does this work with this engine?
Best regards, Chris.
Log-A6 4A .txt
 File name:  Log-A6 4A .txt
 File size:  2.95 KB
 Downloaded:  1224 times
A6 AFB
A6 BRE DPF
Post18-08-2011, 18:03    Subject: S6 4A Treadmill System 1791 Quote
Okay, I'm ready. Please provide the text you want me to translate from German to English.
Okay, I'm ready. Please provide the German text you want me to translate.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post19-08-2011, 14:19    Subject: S6 4A Treadmill System 1791 Quote
Is the AHK (Anhängerkupplung - trailer hitch) actually installed in the S6 Plus, or not? icon_wink.gif
EDIT: This is a copy from someone else; I am not the author, but it worked very well for me.
Reset the control unit and retrain the learned values.
Remove the ignition key if you haven't already.
Disconnect the battery and wait for at least 30 minutes.
After at least 30 minutes, insert the ignition key and turn it to the "on" position!
Connect the battery and leave it like that for 10 seconds - Battery connected and ignition key in the "on" position!
Start the engine without giving it any gas, and then do nothing else. Let the climate control run without turning on any lights or anything else – just let it run. This should run for at least 30 seconds.
Turn off the engine after at least 30 seconds of running!
Turn the ignition back on and wait for 10 seconds.
After 10 seconds, restart the engine as mentioned above, and let it run idle for another 30 seconds.
After 30 seconds, turn off the engine, remove the ignition key, and that's it.
Have fun!
EDIT 2: By the way, you can very nicely disassemble your climate control servo motors and clean the slip rings from the carbon brushes, and they will function like new again icon_wink.gif.
