Timing Belt AFB: Installation & Torque Specs
mserge
Post11-10-2011, 16:08    Subject: Timing Belt AFB: Installation & Torque Specs Quote
Hello, does anyone have the timing specifications for the timing belt and ribbed belt on the AFB engine?
The search is not yielding any results.
Thank you very much.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 29-09-2026, 17:40.
Deus Violentia
Post11-10-2011, 16:15    Subject: Timing Belt AFB: Installation & Torque Specs Quote
For an Audi A4 Avant AFB, manufactured in 2000, it looks like this:
Component Nm.
Camshaft gear on camshaft 75.
Vibration dampers for injection pump rotor 22.
Drive wheel for injection pump, mounted on camshaft 22.
Vacuum pump connected to cylinder head 10.
Vibration dampers on crankshaft gear 22.
Cylinder block drain plug 10.
Tensioner pulley for the ribbed V-belt of the air conditioning compressor, mounted on bracket 22.
Tensioner pulley for the fuel injection pump, mounted on the bracket for the viscous fan coupling, 36.
Have fun!
BKD GRF
AHF EBF
Translated on 29-09-2026, 17:42.
mserge
Post11-10-2011, 16:23    Subject: Timing Belt AFB: Installation & Torque Specs Quote
Surely there must be more roles and fasteners available, right?
@DeusViewing profile: Deus: You have mail icon_smile.gif.
Thank you again.
Translated on 29-09-2026, 17:43.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Suspension Upgrades: Suitability & Performance Upload
No new posts Audi A4 B5 Suspension Upgrade Options Transmission, Chassis, Body & Interior
No new posts Lug bolts for brake carrier, Audi A4 8K Transmission, Chassis, Body & Interior
No new posts Tightening torque for timing belt replacement on PD engines? Diesel Engine Technology
