Error codes and their possible causes for MKB AKN (Solution)
Michael II
Post06-06-2002, 12:16    Subject: Error codes and their possible causes for MKB AKN Quote
Error Codes and Their Causes for the AKN Motor
{ERROR_CODE_1}: {CAUSE_1}
{ERROR_CODE_2}: {CAUSE_2}
{ERROR_CODE_3}: {CAUSE_3}
Error Code: 513
G-code for motor speed G28 impossible signal
Possible Causes:
G28 error
Distance between speed sensor/encoder wheel is too large
Metal shavings on the G28 or mounting socket.
no signal
Possible Causes
Circuit interruption or short circuit
Error Code: 519
Donor for suction tube pressure - G71 Short circuit to positive.
Possible Causes:
Short circuit after plus
G71 defect
Interruption/Short circuit
Possible Causes:
Circuit interruption or Short circuit to ground
G71 defect
Power supply
Possible Causes:
Error Code: 522
Sender for Coolant Temperature G62 Short Circuit to Ground
Possible Causes:
G62 failure
Head has short circuit to ground.
Interruption/Short circuit after plus
Possible Causes:
Circuit interruption or Lead short to positive
Error Code: 523
Giver for Intake Air Temperature G42 Short to Ground
Possible Causes:
G42 failure
Head shorted to ground
Possible Causes:
G42 failure
Circuit interruption or Short circuit after plus
Error Code: 532
Supply voltage: Implausible signal
Possible Causes:
Intermittent connection failure (loose contact)
Signal too small
Possible Causes:
Discharged Battery
Bad connection to the engine control unit
Possible Causes:
Relay for power supply, terminal 30 (J317) defective
Open entrance
Possible Causes:
Battery within 10 minutes after
Disconnecting the ignition
Error Code: 534
Sender for Oil Temperature G8 Short Circuit to Ground
Possible Causes:
G8 defect
Sender for Oil Temperature G8: Unrealistic Signal
Possible Causes:
G8 defect
Error Code: 539
Fuel Temperature Sensor G81 Short to Ground
Possible Causes:
G81 defect
Interruption/Short circuit after positive terminal
Possible Causes:
G81 defect
Error Code: 542
Donor for Needle Stroke G80 Interruption/Short Circuit to Plus
Possible Causes:
G80 failure
unplausible signal
Possible Causes:
G80 failure
Fuel line to cylinder 3. Cylinder not OK.
Fuel shortage
Air in the fuel system
Error Code: 550
Spritzbeginnregelung: Regelabweichung, Überschreitung oder Unterschreitung der Regelgrenze
Possible Causes:
Injector start valve (N108) defective)
Needle lift actuator (G80) defective
Fuel tank emptied.
Fuel supply not OK.
Fuel shortage
Funding start is okay.
Error Code: 553
Air Mass Meter G70 - Unrealistic Signal
Possible Causes:
G70 malfunction
Interruption/Short circuit to ground
Possible Causes:
Possible Causes:
G70 malfunction
Error Code: 560
Exhaust Gas Recirculation Regulatory Difference
Possible Causes:
Incorrect breathing
Exhaust gas recirculation (EGR) valve is faulty.
(Valve is stuck, diaphragm rod is not moving)
Hoses reversed, not attached, clogged or leaking
Error Code: 575
Suction tube pressure, control difference
Possible Causes:
Magnetic valve for pressure limiting (N75) is defective
Incorrect hose connections, not attached, leaking
Leak between turbocharger and engine (intake duct)
Turbocharger failure
Error Code: 625
Speed signal impossible signal
Possible Causes:
No signal from the sensor for the speedometer (G22)
Error Code: 626
Control lamp for pre-glow time K29 Interruption/Short circuit to ground
Possible Causes:
Light bulb is broken.
Possible Causes:
Error Code: 628
Job Title Monitoring: Unrealistic Signal
Possible Causes:
Fuel pump failure
Interruption/Short circuit to ground/ Circuit interruption
Possible Causes:
Possible Causes:
Interruption/Short circuit to positive/ Circuit interruption
Error Code: 668
Line voltage, terminal 30, implausible signal
Possible Causes:
Relays for Power Supply
Clamp 30 (J317) is defective
Relay is (occasionally)
Error Code: 671
Switch for GRA -E45 undefined switch state
Possible Causes:
E45 is broken.
Error Code: 741
Brake Pedal Monitoring - Unplausible Signal
Possible Causes:
Brake light switch (F) is faulty
Brake Pedal Switch (F47) - Defective
Error Code: 777
Gas pedal position sensor G79 - Unplausible signal
Possible Causes
G79 failure
Possible Causes
G79 failure
Power supply
Possible Causes
Error Code: 1028
Relay for Fans J323 Disconnect/Short to Ground
Possible Causes:
Circuit Interruption
Relay failure
Possible Causes
Error Code: 1044, 18008
Tax device incorrectly coded
Possible Causes:
Invalid ECU coding
Error Code: 1117
Overload signal for generator terminal DF - Unplausible signal
Possible Causes:
Generator malfunction
Voltage regulator failure
Error Code: 1126
Signal for motor speed Signal outside the tolerance
Possible Causes:
No signal
Fuel pump failure
Error Code: 1180
Motor/Air Conditioner Compressor - Disconnect Electrical Connection Short Circuit to Positive (+)
Possible Causes:
Short circuit in the pipeline
Error Code: 1259
Fuel pump relay J17, Open/Short to Ground
Possible Causes:
Fuel pump relay failure
Possible Causes:
Error Code: 1262
Magnet Valve - Charging Pressure Limiter - N75 - Open/Short to Ground
Possible Causes:
Magnet valve malfunction
Possible Causes:
Error Code: 1265
Ventil for Exhaust Gas Recirculation N18 Interruption/Short Circuit to Ground
Possible Causes:
Possible Causes:
Error Code: 1266
Text Relay for Filament J52 Open/Short to Ground
Possible Causes:
Relays for light bulbs are faulty.
Possible Causes:
Error Code: 1268
Set N146 Regulatory Difference
Possible Causes:
Fuel pump failure
lower threshold value
Possible Causes:
Counter mechanism malfunction
Metering system blocked due to dirt
upper limit value
Possible Causes:
Error Code: 1282
Switch valve for suction pipe valve N239, Disconnect/Short circuit to ground
Possible Causes:
Circuit interruption or short circuit to ground
Possible Causes:
Error Code: 1318
Injector pump control unit J399 defective
Possible Causes:
Fuel pump failure
no communication
Possible Causes:
Data signal to the fuel pump is faulty.
Error Code: 1375
Valves for Engine Storage Level 1 Disconnect/Short Circuit to Ground
Possible Causes:
Motor bearing (N144) or (N145) is defective
Possible Causes:
Error Code: 1376
No signal for the fuel pump speed signal.
Possible Causes:
Fuel pump not turning
Timing belt for fuel pump snapped.
defekt
Possible Causes:
Fuel pump failure
Error Code: 1440
Fuel Level Signal Interruption/Short Circuit after +
Possible Causes:
Short circuit to ground.
Possible Causes:
Error Code: 1441
Source: Fuel shortage G210 Interruption/Short circuit after positive terminal
Possible Causes:
G210 failure
Possible Causes:
G210 failure
unplausible signal
Possible Causes:
Fuel pump not working
Empty storage compartment
G210 failure
Error Code: 1442
Outages due to fuel shortage
Possible Causes:
Tank empty
Error Code: 1686
Steuergerät for radiator fan auxiliary J138: Interruption/Short circuit to ground
Possible Causes:
J138 defect
Ausgang does not switch on / Short circuit to positive.
Possible Causes:
Error Code: 17931
Crash-Signal from Airbag System: Unplausible Signal
Possible Causes:
Error in the data lines to the airbag control unit
17978
Engine control unit malfunction.
Possible Causes:
Attempt to start with unauthorized user
Key.
Attempt at manipulation
Short circuit of the
Communication Manager
Incorrect encoding
Errors in the system for
Immobilizer
Ignition control unit
defekt/missing
Engine control unit replaced and not working
Immobilizer adjusted.
Error Code: 18017
Crash shutdown initiated.
Possible Causes:
Airbag deployed.
Error Code: 65535
Taxation device J248 defective
Tschüss
Michael II
Ratings - Error codes and their possible causes for MKB AKN
No new posts Error codes and their possible causes for MKB AFN, AVG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for engine types 1Z... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for Mercedes-Benz AHD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Values: Meaning and Impact Diesel Engine Technology
No new posts Engine Power 1Z for Given LD Value Diesel Engine Technology
No new posts Performance Variations: Causes and Solutions Diesel Engine Technology
No new posts Idling Oxygen Sensor: Causes of -2.4mg/H Reading Diesel Engine Technology
