Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
garth.brooks
Post20-09-2011, 19:39    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
Hello everyone,
My VP37 (1998 AFN) is leaking fuel at the seal where the MSW connects to the pump housing.
I'm confident enough to remove the MSW (Multi-Station Washer) while it's installed, replace the seal, and reinstall it on the housing.
However: The MSW is attached with 4 screws that run in elongated holes on the MSW, allowing for a loose movement of a few millimeters.
On the other hand, the amount of movement of the slide between idle and full throttle is quite small, in my opinion, less than the amount of movement possible due to the elongated holes.
From my experience, even slight deviations from the pump's target value can cause the MSG to issue an error and the yellow light to turn on.
Question:
Has anyone ever done this before without the pump needing to be put on a test stand afterward?
If so, how did he find the position of the quantity setting device again?
How critical is it, really?
'Die Sonne schien hell, als ich aus dem Haus ging. Der Himmel war blau und es gab keine Wolken. Ich fühlte mich glücklich und voller Energie.'
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post20-09-2011, 19:48    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
It's all explained in the technical articles.
Greetings.
garth.brooks
Post20-09-2011, 20:22    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
That's explained in the technical articles on how to do it.
Greetings
Okay, here's the translation:
'So?' In which one?
If I had found something through searching, I wouldn't be asking.
Karma: +1344 / -0   Thank you, like it!
Post20-09-2011, 21:01    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
Look over there.
/viewtopic.php?t=21803&highlight=mengenstellwerk
klahaui
Avatar-klahaui
Post20-09-2011, 22:48    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
Right next to the search bar, there's a section labeled "Fachartikel," and it's even written in red icon_rolleyes.gif.
garth.brooks
Post21-09-2011, 9:37    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
@ Thanks to Herbert, that's exactly what I was looking for.
He clearly managed to do it, so I can too.
Post21-09-2011, 10:35    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
And as I said - First measure - then screw - otherwise, it might happen that you have to have someone else install it, which can be expensive icon_wink.gif.
garth.brooks
Post12-11-2011, 22:54    Subject: VP37 sealed / sealing Quote
I have now managed to seal my VP37 again.
I built a mechanical stop and adjusted it precisely using 0.1mm shims.
Then I screwed two bolts into the screw holes, using them as guide pins.
The rest was easy: carefully lift off the flow meter, replace the seal, carefully put it back on - and it's done.
The engine is running as before, without any problems.
 Mengenstellwerk VP37
 File name:  IMG_1584.JPG
 File size:  750.98 KB
 Downloaded:  4389 times
 VP37 Einspritzpumpe geöffnet
 File name:  IMG_1583.JPG
 File size:  1.04 MB
 Downloaded:  14276 times
 Mengenstellwerk VP37 ohne Deckel
 File name:  IMG_1581.JPG
 File size:  1.09 MB
 Downloaded:  3987 times
benpeu likes this.
Post13-11-2011, 0:05    Subject: Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine in its installed state Quote
So, I built a mechanical stop, and I adjusted it precisely to 0.1 millimeters using a feeler gauge.
Well done, it certainly took longer, including measuring and building, than it would have taken to check the start/stop voltage or the idle injection amount using VCDS (5 minutes). icon_cool.gif
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Checking the TSI fuel injectors in their installed state? Gasoline Engine Technology
No new posts VP44: Seal & Disassemble - Repair Guide Diesel Engine Technology
No new posts VP37: Troubleshooting Internal Housing Issues Diesel Engine Technology
No new posts Cost for sealing PDEs Diesel Engine Technology
