Replacement value for coolant temperature sensor (CTS) when disconnected
Klausel
Post12-11-2011, 14:37    Subject: Replacement value for coolant temperature sensor (CTS) when disconnected Quote
"When I disconnect the sensor, VCDS displays a value in column 4 of row 7 in the Measurement Control module."
which surprisingly corresponds exactly to the value of the fuel temperature.
It matches (the ambient temperature was around 20°, and the intake air temperature was 13°).
Actually, I was expecting a much lower value because you can achieve this with...
Removing the sensor is said to sometimes cause a start-up issue.
can simulate very low temperatures.
Does anyone know what's going on?
Best regards, Klaus.
Polo 6R, TSI 110 PS
Translated on 10-07-2026, 14:32.
Post12-11-2011, 17:55    Subject: Re: Replacement value for coolant temperature sensor (removed) Quote
Klausel wrote:
When I disconnect the sensor, VCDS shows a value in module control (MWB) column 4, row 7.
Removing the sensor is said to sometimes help with starting the engine.
Greetings Klaus
If a sensor fails and is detected as defective, the engine control unit attempts to use an appropriate substitute value, depending on the software version (meaning the behavior may not always be consistent).
In your case with the AFN engine, it's the fuel temperature sensor, which makes sense given the temperature conditions during engine start-up.
It is still advisable to replace the coolant temperature sensor as soon as possible, because otherwise various parameters, such as the injection timing, may no longer be accurate.
Translated on 10-07-2026, 14:35.
Karma: +1344 / -0   Thank you, like it!
Post13-11-2011, 11:46    Subject: Replacement value for coolant temperature sensor (CTS) when disconnected Quote
Hi there,
The 1Z engine supports both functions: providing a substitute value for the temperature (fuel temperature) and enabling extreme cold start conditions with extended preheating when "ignition is on." This may also apply to the AFN engine.
That all makes sense. In the event of a failure in the coolant temperature sensor, the engine control unit (ECU) can at least provide limited regulation, the auxiliary heater only operates according to the "coolant temperature" reading, and cold starting with preheating still functions.
Translated on 10-07-2026, 14:37.
No new posts Afterglow with disconnected temperature sensor (AHU) Diesel Engine Technology
No new posts 1Z: Drive with disconnected boost control valve? Diesel Engine Technology
