Passat 3B Headlight Vibration: Troubleshooting Guide (Solution)
Michael II
Post28-07-2003, 9:28    Subject: Passat 3B Headlight Vibration: Troubleshooting Guide Quote
Headlight vibrates.
Cause:
In some vehicles, vibrations in the headlights can occur due to insufficient securing of the headlight units.
up to chassis number.
3B3 E 322 602
Solution:
The vibrations can be corrected by the following measures.
Loosen all screws and realign the entire headlight assembly so that it sits flush against the bumper. Tighten the lower screws first, then the upper screws. After tightening the screws, the alignment can be easily checked by inserting strips of paper between the bumper and the headlight.
Checking the engine mounts and suspension to reduce engine vibrations.
Tschüss
Michael II
Translated on 23-09-2026, 5:50.
Ratings - Passat 3B Headlight Vibration: Troubleshooting Guide
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about foggy headlights and odors inside Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG Headlight Reflector Transmission, Chassis, Body & Interior
No new posts Audi A8 3.3 TDI AKF Vibration Problem Diesel Engine Technology
No new posts Vibrating Cooler Fan: Troubleshooting & Fixes Diesel Engine Technology
No new posts A4 BPW vibrates/jerks Diesel Engine Technology
