Various measures.
Affected vehicle identification numbers:
1T Z 3W 000 186 to 1T Z 3W 009 177.
Attention:
In all 8544 affected vehicles, the electric control unit (ECU) will be replaced.
replaced.
For Touran vehicles within the affected vehicle identification number (VIN) range, quality improvement measures must be implemented.
Selection criteria: 01 Replacement of electrical box.
Body control module (BCM), clutch slave cylinder, seat belt.
Tighten the screws on the belt buckle and seat crossbar.
(Seats 5) or
(7 seats).
Replace the vehicle's body control module.
Properly coding the vehicle's body control module.
Replace clutch slave cylinder (only for 1.9L diesel engines).
Replace the electrical box, check for water ingress, water tank.
revise.
Spare parts:
1x E-Box, Part Number: 1K0 937 124 H
1x Cover, Part Number: 1K0 937 132 D
Only when needed.
1x Clutch Slave Cylinder, Part No.: 1K0 721 261.
2x Brake fluid, 0.1l, Part No.: B 000 700 S0.
1x Body Control Module (BCM), Part Number: 1K0 998 049.
The customer notification from VAG is no longer required. Each individual dealer is responsible. Tschüss
Michael II
Translated on 05-10-2026, 18:25.
