Four-valve technology in a V10 TDI engine?
vwSchrauber
Post06-12-2011, 17:26    Subject: Four-valve technology in a V10 TDI engine? Quote
Do the V10 TDI PD engines actually have four-valve technology and centrally located common rail injectors (PDE), or do they still use the older system where the PDE wears away the aluminum of the cylinder head? It's difficult to find more detailed technical data about these engines; everywhere you look, people are just boasting about power and torque figures icon_rolleyes.gif.
Translated on 18-07-2026, 10:39.
vwSchrauber
Post06-12-2011, 17:53    Subject: Four-valve technology in a V10 TDI engine? Quote
"Thank you!"
However, it's only a two-valve system... I never would have guessed icon_confused.gif.
Translated on 18-07-2026, 10:40.
Post06-12-2011, 18:15    Subject: Four-valve technology in a V10 TDI engine? Quote
V10 TDI engines are essentially two R5 TDI engines arranged in a "V" configuration.
Therefore, they also have things like the ring gear drive, for example. icon_wink.gif
Edit: I have removed the link because these documents are subject to copyright! Please note!
exciter
Registered VCDS User
Post06-12-2011, 18:51    Subject: Four-valve technology in a V10 TDI engine? Quote
Oh, sorry.
I didn't know they were so widespread.
Now I know it icon_smile.gif.
Translated on 18-07-2026, 10:41.
chli1976
Post06-12-2011, 22:20    Subject: Four-valve technology in a V10 TDI engine? Quote
Yes, the cylinder heads look like those from an R5; I actually have one of those engines here right now. It has a turbocharger failure.
VCDS
vwSchrauber
Post07-12-2011, 17:20    Subject: Four-valve technology in a V10 TDI engine? Quote
I also thought that, because you can actually buy those things, as far as I know...
The V10 TDI engines are essentially two R5 TDI engines in a V configuration.
Therefore, also the aluminum block with the sprayed-in cylinder liners, which then detach icon_rolleyes.gif.
Translated on 18-07-2026, 10:42.
