Wassereinspritzung selbst bauen | Posts 16+
Go to page: Previous  1, 2
gullianderle
Post22-12-2011, 17:18    Subject: Quote
'Furthermore, I see a problem with low temperatures. The water will unfortunately freeze. Adding antifreeze would be very annoying for the participants due to the extreme smoke it would produce. If alcohol (such as spirits or methanol) is added, it becomes uneconomical.' Otherwise, I think the idea is very good. icon_confused.gif
comco
Karma: +1 / -3   Thank you, like it!
Registered VCDS User
Post22-12-2011, 19:35    Subject: Quote
Herbert wrote:
You are using the term "Verpuffung" incorrectly.
Ouch, that hurts. You shouldn't look at the water content in isolation, as diesel fuel and high pressure/temperatures are also involved in the combustion process.
It's clear that you lack practical experience in applying water injection, and therefore also lack comparative data.
Once again, regarding the basics:
No steam is injected into the LL section; instead, extremely fine water droplets are introduced, and these droplets no longer exhibit the dew point you mentioned.
Even if the intercooler temperature is close to the normal boiling point of water, no (complete) vaporization still occurs.
Herbert wrote:
...and the addition is adjusted according to air mass and temperature.
No, this system only works with pressure!
Herbert wrote:
...To achieve this, more diesel is injected,...
No, not with the system that applies here!
When it's freezing and the low-temperature coolant (LLK) system is not functioning properly, water injection is not as effective in lowering the LLK temperature. Otherwise, the windshield washer reservoir can also be tapped, especially if the windshield washer fluid contains antifreeze additives such as alcohol. You can't smell anything from it.
But never use coolant antifreeze when injecting water!
Bye
Jürgen
_________________________________________
Für den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
Für noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Karma: +1344 / -0   Thank you, like it!
Post22-12-2011, 20:17    Subject: Quote
Hi Comco,
I think we should stop discussing this further, as it seems like some people aren't understanding what's being said.
Find out what menthol is, what methanol is, what a deflagration is, etc., before you start writing things randomly.
g
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Build your own VAG connector Diesel Engine Technology
No new posts DIY Book Sorting System: Build Your Own! Diesel Engine Technology
No new posts OBD-2 interface for Audi/VW - build it yourself On-Board Diagnostics (OBD)
No new posts Water injection in TDI engines Diesel Engine Technology
