Log File Idle State: Full Reproduction Now Available.
alevuz
Karma: +32 / -0   Thank you, like it!
Post26-12-2011, 11:23    Subject: Log File Idle State: Full Reproduction Now Available. Quote
I tried to log the idle speed control (where all 10 cylinders are between -0.8 and +0.8 mg/H icon_biggrin.gif) on my Touareg (V10).
Control unit cluster 31 was selected (due to the 2 control units), and measurement blocks 13/14 were logged for approximately 1 minute each.
"It obviously worked well, however, when I try to view these files with KDataScope, the playback always stops around 16-18 seconds."
Thank you in advance for your help.
Have a nice day.
*Alevuz*
Touareg V10 TDI (AYH)
Translated on 02-09-2026, 21:30.
Post26-12-2011, 11:42    Subject: Log File Idle State: Full Reproduction Now Available. Quote
Please upload the log file here...
Translated on 02-09-2026, 21:31.
alevuz
Post26-12-2011, 16:24    Subject: Log Files Attached: Troubleshooting & Analysis Quote
Attached are the two log files from the Touareg!
Perhaps someone could check the files for any abnormalities and confirm or correct my amateur assessment that, overall, the little engine seems to be in not bad condition.
Thank you and best regards.
Alevuz.
LOG-31-014-xxx-xxx.CSV
 File name:  LOG-31-014-xxx-xxx.CSV
 File size:  5.78 KB
 Downloaded:  500 times
LOG-31-013-xxx-xxx.CSV
 File name:  LOG-31-013-xxx-xxx.CSV
 File size:  16.43 KB
 Downloaded:  479 times
Translated on 02-09-2026, 21:32.
Post26-12-2011, 18:34    Subject: Log File Idle State: Full Reproduction Now Available. Quote
The values in the files are generally okay, so I don't see any immediate danger to the engine regarding this issue.
Each log file contains 2 logs (sequentially), and KDataScope displays the first one.
A possible improvement would be to include a selection field in the file information section that allows the user to choose which log file they would like to view.
Generally, it is more sensible to use only one log file per file, for example, to group by engines and functions. Therefore, the file name cannot be chosen arbitrarily without a good reason. icon_wink.gif
Translated on 02-09-2026, 21:33.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts 1 x Log file for engine control module (ECM) code MWB0 an... Upload
No new posts [1.9 TDI] BKC Correction value for the running idle control Diesel Engine Technology
No new posts Idling speed control 85kW PD /AJM Diesel Engine Technology
No new posts Logfile Golf IV TDI 008-010-011 Upload
