I've had a water leak in the rear left side of my A6 C4 Avant for quite some time now. It's time to do something about it. I've traced a moss-covered stream up to a mounting tab where the small, painted panel (at the bottom of the window) is clipped into the exterior of the D-pillar.
How do you remove it without causing damage?
Are there any other well-known water sources back there?
Best regards, Kai.
| Description: |
| Water Leak Repair: Audi A6 Avant Rear Panel Removal |
| File size: |
25.1 KB |
| Viewed: |
1623 times |
Translated on 03-09-2026, 15:17.
