Oil Consumption: VW Golf IV "Longlife" Problems
pepe
Post18-07-2003, 21:31    Subject: Oil Consumption: VW Golf IV "Longlife" Problems Quote
Unfortunately, it's about a Volkswagen Golf IV with a 75 horsepower gasoline engine (manufactured in 2002). Since the workshop doesn't know what else to do, I'm looking for your advice.
[If this is not desired, please delete this thread.]
The Golf has a long-life oil system, and it's consuming more than a liter of oil every 1000 km. After reading the error codes, the following errors were found:
Engine control unit (ECU)
6 errors found:
16645 - Injector valve, cylinder 1: Short circuit to positive (N30).
35-10 - - - Intermittent
16651 - Injector valve, cylinder 3, short circuit to positive (N32).
16654 - Injector valve, cylinder 4: Short circuit to positive (N33).
16648 - Injector valve, cylinder 2: Short circuit to positive (N31).
17833 - Fuel tank ventilation valve interruption (N80)
17525 - Bank1-Probe2: Heating circuit interruption.
Thank you for your information, advice, and everything else.
Translated on 07-08-2026, 1:43.
chris11
Karma: +3 / -1   Thank you, like it!
Post19-07-2003, 16:32    Subject: Golf 4 Oil Consumption Problem - High Mileage? Quote
Hello Pepe,
The error codes you're seeing (intermittent) are likely not directly related to your oil consumption. How many kilometers has the engine driven? Is it a 2002 model? Oil consumption of 1 liter is more indicative of a mechanical issue within the engine. What work has the workshop already done?
The year of manufacture being 2002 suggests this might be a warranty issue.
Christian.
Translated on 07-08-2026, 1:46.
pepe
Post19-07-2003, 19:36    Subject: Oil Consumption: VW Golf IV "Longlife" Problems Quote
It's not my car, but rather my girlfriend's... your mother's.
A new oil filter was installed at the workshop, which the mechanics claim has better ventilation. Nothing else was done. Oh, and one liter of oil was added, which, of course, wasn't covered by the warranty...
The car has only 23,000 km on the odometer, so it hasn't even had its first service yet.
The car needs to be driven until the next service, which is at 25,000 km, and then we can assess the situation further. It was promised that, if no cause for the oil leak is found, a replacement engine would be provided under warranty.
Translated on 07-08-2026, 1:47.
Post19-07-2003, 21:10    Subject: Golf 4 Oil Consumption Problem - High Mileage? Quote
"Hi,"
pepe wrote:
Engine control unit.
6 errors found:
Okay, regarding the errors "...short circuit to positive...", I would start by checking the ground connection. Since this involves the control for the fuel injectors, please check the grounding strap between the chassis and the engine, as well as the transmission. Grounding issues are very common. If this error disappears, the other errors usually resolve themselves.
Translated on 07-08-2026, 1:49.
pepe
Post20-07-2003, 10:05    Subject: Oil Consumption: VW Golf IV "Longlife" Problems Quote
'@Bertil: That would make sense, you're right. 'Intermittent' means occurring sporadically or repeatedly, which is similar to a loose connection.'
I'll definitely check the wiring, thanks...
Translated on 07-08-2026, 1:50.
engelchen
Post30-07-2003, 15:35    Subject: Oil Consumption: VW Golf IV "Longlife" Problems Quote
I'm having the same problem...
Volkswagen Golf IV, 75 horsepower, manufactured in 2000, with 30,000 kilometers (approximately 18,641 miles) on the odometer.
Oil consumption: approximately 1 liter per 1000 km.
My workshop says they can't find any fault and refers to the operating manual, which states that such consumption is 'normal'...
A friend of mine (a certified automotive mechanic) told me to be careful and make sure there's no engine damage.
Does anyone here have any ideas or experiences that might be helpful to me?
Translated on 07-08-2026, 1:51.
No new posts Golf 1J Wiper System Not Working? Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts L200 Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
No new posts 115 HP PD AJM engine without longlife oil? Diesel Engine Technology
No new posts TDI Engine: The End? Diesel Engine Technology
No new posts Large Language Models: No End in Sight Diesel Engine Technology
