Blauqualmvideo nach Kaltstart: 1,9 PD-TDI | Posts 16+
Go to page: Previous  1, 2
Post02-02-2012, 7:49    Subject: Quote
Okay, then we apparently need to delve into the microcosm of diesel and Möltrop particles, along with their combustion process, under different surrounding temperatures icon_confused.gif.
This leads me to the question of whether the blue smoke in the video might also be caused by poorly atomized diesel fuel (due to PDE defects) or a lack of glow plug heat.
Or is blue smoke always caused by oil?
Once the motor no longer cools the compressed air to an extreme degree, the motor can also cleanly burn off a small amount of oil.
What I still find interesting is the new blue smoke that appears during the short bursts of gas in the video, even though the exhaust seemed clean beforehand.
I spontaneously assumed that the briefly revving turbocharger would expel some new oil, which would then be (badly) burned.
But why, according to the owner, does the blue smoke disappear when the engine is warmer? Could the turbocharger still be leaking oil, which simply burns more inconspicuously in a warmer environment?
Are there any other possible oil leak sources in the 1.9 PD TDI engine that could cause leaks when the engine is warm?
Translated on 12-09-2026, 21:32.
Karma: +1099 / -0   Thank you, like it!
Post02-02-2012, 9:55    Subject: Quote
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Translated on 12-09-2026, 21:34.
Post02-02-2012, 13:54    Subject: Quote
ulf wrote:
This leads me to the question of whether the blue smoke in the video might also be caused by poorly atomized diesel fuel (problems with the common rail injectors) or a lack of glow plug heat.
Yes!
No...
Blackfrosch
Post03-02-2012, 0:23    Subject: Quote
As long as all the glow plugs haven't been checked, I strongly believe that they are the cause of the excessive smoke. When there's a sudden surge of gas, it also inadvertently introduces more diesel. If the glow plugs or their relay are completely defective, it looks like this - as it appears. For example, even a Seat Ibiza SDI smoking like crazy down the street at -10°C.
The rather large direct injection (GDI) nozzles of the Cupra certainly aren't world champions in terms of injection pressure at idle. Therefore, the atomization is quite poor, and without afterglow, it likely continues to burn "unevenly."
Hello FabiaCombiTDI.
Translated on 12-09-2026, 21:35.
Post03-02-2012, 7:19    Subject: Quote
FabiaCombiTDI wrote:
During the gas surge, a random amount of diesel also enters.
This lasts for about 1 second, during which the engine is supposed to rev up. However, the subsequent blue smoke lasts for what feels like 10 times as long. icon_eek.gif
. The rather large fuel injectors from the Cupra, of course, are not world champions in injection pressure at idle.
The entire BPX fuel injection hardware is identical to the ASZ, the injectors are "only" 550cc.
Translated on 12-09-2026, 21:36.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Oil warning light after cold start, all models ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cold Start Problems? Emergency Mode Explained. Diesel Engine Technology
No new posts Blaurauch nach Kaltstart V6 AKN Diesel Engine Technology
No new posts Loader Piping After Cold Start Diesel Engine Technology
No new posts TDI Cold Start: Emergency Mode Troubleshooting On-Board Diagnostics (OBD)
