Keilrippenriemen läuft ab | Posts 16+
Go to page: Previous  1, 2
DieselBär30x
Avatar-DieselBär30x
Post10-02-2012, 11:21    Subject: Quote
Hello everyone!
Roger wrote:
Didn't we once have a case where one of the pulley wheels was damaged due to... Bearing defect, running at an angle?
Are you not confusing this with a timing belt slippage issue on (presumably) 1Z/AFN (or something similar), where the cause was a worn-out ESP mounting?
Best regards from Munich!
Post10-02-2012, 11:49    Subject: Quote
DieselBär30x wrote:
Are you not confusing this with a timing belt slippage issue on (presumably) a 1Z/AFN (or something similar), where the cause was a worn-out ESP bearing?
No, I mean, we had something like that in a quiz before...
das-weberli
Post10-02-2012, 13:53    Subject: Quote
Okay, hier ist die Übersetzung:
'This is about a Golf AFN.' He used the same 'standard' spring mechanism as he did with the 1Z.
The A4 AFN and Passat AFN also have a spacer element.
Later engines were the ones that incorporated the spring/damper combination.
The part in the third picture is also a spring element; you can even see the ends of the coil spring. icon_wink.gif
You're right that the strut is just a simple component with a coil spring, but over the years, that part can also become worn out.
As I mentioned, the belt on my Golf started 'fluttering.' Even the new one was fluttering.
It got slightly better when I used a shorter belt, and eventually stopped completely when I replaced the tensioner.
DieselBär30x
Avatar-DieselBär30x
Post10-02-2012, 14:00    Subject: Quote
Roger wrote:
...no, I mean, we had something like that once in a quiz...
Now that you mention it, I'm starting to understand.
I think that was a bent tensioner arm from a 2.5-liter engine, and it was posted by someone from the GTI forum?
ABär, that was about the belt wear pattern, not the belt shedding (I'm saying this very cautiously! icon_wink.gif ).
dieter
Karma: +13 / -0   Thank you, like it!
Post10-02-2012, 14:10    Subject: Quote
dieselmartin wrote:
The belt runs over the crankshaft, tensioner, alternator, and water pump.
Everything has been converted according to VW's specifications (industrial engines) using original parts.
Why industrial engines?
That's the normal KRR (Knock Return Rate) behavior of a G3 TDI engine without air conditioning.
The servo on my MJ 96 1Z was connected using a separate V-belt.
Yes, that's the normal way. I had an engine with air conditioning and power steering, but I had to modify it.
VW also provided an instruction manual for industrial engines, which included details on all belt-drive variants, along with parts lists. That's all, I'm sure there were other ways to achieve the same result.
dieter
T3 syncro 16 AFN
das-weberli
Post10-02-2012, 14:47    Subject: Quote
In that case, you would have the timing belt system from a Golf 3 1.9 TDI without air conditioning.
The servo in those models uses a small V-belt, regardless.
You can also remove the KW pulley for the power steering, but it's not necessary.
dieter
Post10-02-2012, 16:22    Subject: Quote
das-weberli wrote:
In that case, you would have the timing belt from a Golf 3 1.9 TDI without air conditioning.
Sure.
das-weberli wrote:
You can then also remove the KW pulley for the power steering, but you don't have to.
"I did, but it's usually very crowded on the bus."
Okay, it's the weekend now, maybe I can report back on Monday.
Goodbye.
dieter
T3 syncro 16 AFN
das-weberli
Post10-02-2012, 20:00    Subject: Quote
Is it crowded on the bus?
I have only seen 2.9 VR6 and 2.3 5-cylinder engines in vans icon_cool.gif in person so far.
dieter
Post13-02-2012, 9:55    Subject: Quote
It depends on what changes you want to make. With the double pulley, the exhaust would have to be removed in order to install the belt.
Besides, I didn't need it anyway.
Regarding the actual topic, I'm afraid I'm no smarter than I was before.
On Saturday, I installed the new belt and the engine started up and is running.
Tested it again on Sunday with a cold engine, and it works.
Everything is smooth and easy to operate, nothing is loose or bent, and the freewheel mechanism also works.
I suppose I'll have to keep observing.
Thank you everyone for the tips.
dieter
T3 syncro 16 AFN
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 TDI, squealing ribbed belt, TPI Diesel Engine Technology
No new posts Serpentine belt squealing! Diesel Engine Technology
No new posts Power Steering Pump & Serpentine Belt for 1Z Diesel Engine Technology
No new posts V-belt solved!!! Diesel Engine Technology
