Schwache Batterien als Ursache für Elektronik-Bugs? | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Ich habe schon die Batterie getauscht . . .
. . . erst als sie völlig versagte, OHNE daß vorher Elektronikprobleme auftraten
40%
 40%  [ 11 ]
. . . bei leichten Schwächeanzeichen, OHNE daß vorher StG-Defekte auftraten
29%
 29%  [ 8 ]
. . . erst als sie völlig versagte, NACHDEM kurz vorher Elektronikprobleme auftraten
3%
 3%  [ 1 ]
. . . bei leichten Schwächeanzeichen, NACHDEM kurz vorher Elektronikprobleme auftraten
25%
 25%  [ 7 ]
Total votes : 27
Karma: +585 / -0   Thank you, like it!
Post15-02-2012, 21:53    Subject: Quote
Hello!
So far, I haven't personally replaced any control units.
Exception: My father once caused a short circuit while installing a car radio, which damaged some electronic control unit in a Škoda.
Otherwise, I once had an A3 with a short circuit in the fan motor that drained the battery overnight.
After that, the electronics started acting up, but everything could be reprogrammed and fixed.
Golf 4, well, the usual starting speed issue, especially when warm, is a known problem.
In winter conditions at -15°C, it starts easily, but when it's cold, it struggles to start; a new battery helped resolve that issue.
And especially spectacular:
Years ago, with my Corrado:
Without any warning, I got into the car one afternoon, it was summer, and tried to start the engine.
There was a loud bang, and then nothing happened; everything went silent.
The battery exploded, creating a huge hole in it, and the entire engine compartment is now covered in acid.
Translated on 16-08-2026, 5:29.
Post15-02-2012, 22:46    Subject: Quote
As electrical and electronic problems in "modern" cars may occur more frequently once the battery has passed its prime, becoming weaker and therefore buffering voltage fluctuations in the vehicle's internal network (caused by constantly changing loads such as air conditioning fans, electric power steering, blowers, etc.) less effectively.
Yes, unfortunately. The ABS/ESP system is showing intermittent errors or fault entries related to low voltage in the vehicle's electrical system when the car is very cold and many consumers are active.
The battery is from 10/2007.
With VCDS, you can learn more about the condition of the vehicle's battery through the battery management system: https://community.dieselschrauber.org/en/viewtopic.php?t=26290
Translated on 16-08-2026, 5:32.
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KPower 3.0.6: Bug Fixes and Issues Resolved On-Board Diagnostics (OBD)
No new posts Retrofitting a LiFeYPo4 battery charger Electrical Systems, Vehicle Electronics, Multimedia
No new posts Which batteries still have cell caps? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Weak performance after ESP 2.5 TDI adjustment Diesel Engine Technology
